Jun 11, 2017, 09:46 PM
"I will return" Federico
rclad's Avatar
Charging Booma RC li-ion maxpacks
Anyone have experience charging Booma RC li-ion maxpacks. The battery I have is a 2s 7.4V 2800mAh pack. There is no balance lead. My PL6 gives me wrong cell count errors!
Jun 11, 2017, 11:11 PM
These are self balancing batteries, your PL6 has a mode for this it's covered on page 71.
LiPo 1s/2s Small Non Balanced
Special LiPo preset designed for charging small Park Flier type batteries that are not
equipped with balance connectors. Be cautious when charging any LiPo battery nonbalanced.
PowerLab 6 is not capable of detecting imbalance between cells. Never
charge unattended using this preset. This preset is recommended for battery sizes as
small as 10 mAh and up to 2000 mAh. Preset requires manual charge rate settings of
between 10 and 2A in 5 mA increments by default. Fuel Table is optimized for generic
LiPo batteries from C discharge ratings up to 20C. Optimization is for faster charging
with termination settings of C/10 and max of 15 min timeout for C.V. mode. This preset
does not require that every cell in the battery is charged to exactly 100%. If using high C
rate dis-charge batteries (25C and higher), Fuel Gauge readout may not be accurate.
Default charge rate setting is 350 mA. Other defaults: discharge rate setting is 500 mA,
dis-charge voltage 3.3V/cell
Jun 11, 2017, 11:58 PM
rclad's Avatar
Thanks!
Discussion Need some help charging 9.6v li-ion luigirox Electric Power Cars 21 Apr 19, 2016 01:33 PM
Help! Powerlab 6 and Li-ion Charging Rich__B Revolectrix 4 Feb 02, 2016 09:55 AM
Help! Li-Ion Batteries won't charge WhackyPanos Batteries and Chargers 6 Jan 08, 2016 07:57 PM
Question How do I balance charge 2 Li-ion cells in my plane Bird09 Batteries and Chargers 3 Dec 17, 2015 06:08 PM
Question Li ion batteries - Monitoring charge/discharge boblalux Batteries and Chargers 4 Dec 04, 2015 09:50 AM
