Oct 24, 2004, 03:20 AM
Insert custom witicism
Jeff Charlot's Avatar
Build Log
Ray's Me-262
One of the coolest planes ever and one of my personal favorites! Just a burly, tuff Bada$$! I hope to do a good job with this, but there's no way I'll even come close to Henry's finishing skills.
Here's the basic 'kit'.
Oct 24, 2004, 03:25 AM
Fuse needed a little bondo, spot putty as well as some extra glass. I told Ray that I needed it light.....he built it light! A little glass on the inside and I was happy.
Oct 24, 2004, 03:30 AM
The hatch was kind of a bugger to get it to fit right, so I decided to try the 'brute force' method. I glued it in place with CA, slathered bondo all over it and scrubbed the whole area with 40 grit. Perfect!
How do I get this off? Crap.
I may have to do this after I cut out the wing saddle.
Oct 24, 2004, 03:55 AM
Jim in San Diego
Pismo's Avatar
Ahhh, cool. Jeff, are you going to do a complete build thread?
Oct 24, 2004, 10:06 AM
Bill L's Avatar
Jeff I had the same problem with the 262 I built, I used the same method you did, but I temp glued it, sanded it, wrapped the hatch with clear tape, and then applied the bondo, completed sanding it out.
good luck
Bill
Oct 24, 2004, 10:30 AM
ALL IN !
Louied's Avatar
Jeff I d like to see some pics and the method you use to cut the wing saddle if that is not a proplem. I have never seen it done.
Louie
Oct 24, 2004, 03:11 PM
Pismo, I'm gonna try. I'm kinda limited on time, so I'm going to get as much done as I can.
Louie. I'll definately post how I do that. I had to ask Bill when he did his thread.
Bill, glad you did that build thread, I've gone back and checked it a few times. Hopefully I'll do as good a job as you did.
Jeff
Oct 24, 2004, 04:43 PM
Jim in San Diego
Pismo's Avatar
good luck
Bill
So does anyone know of an easier/better way? I'm at the "thinking" stage for the Bearcat (finally got the Mach Dart and M60 flyable) and want to begin soon and the hatch is one of many things I'm wondering about.
I've done some searching under slope and can't find all of the hints I was hoping for so I must be screwing up my searches. I'll keep trying but anything you guys can add (or point me to) in this thread would be great.
I've seen the following and now can't seem to sort through my searches to find (I'm sure I just need to try a little harder though):
A build of a sheeting and glassing a PSS wing (may have been in another full build thread) that was really detailed. IIRC, it showed a lot of detail on how to make the control linkages and surfaces. TFLG's maybe?
I could have sworn I saw a couple of threads on the Bearcat too. One may have been Bill L's and I think the other was RayH's Rarebear.
Now that I'm writing all of this I think I'm motivated to go look again.
Anyway, sorry for the threadjack & I'm all eye's Jeff. Anything you can spare to share is much appreciated. I understand your time - sheesh you're making a lot of planes
Oct 24, 2004, 04:51 PM
Jim in San Diego
Pismo's Avatar
Heh. I just took a look at the Shark thread. There's part of my answers Thx Jeff!
Oct 24, 2004, 04:56 PM
Pismo, whatever I know I'll be happy to share. For the wings, I use balsa and 3M and will solartex. Some folks like using ply and glass, but it's a bit heavy for me. Check out Bill's thread from when he build a 262, lots of great info there. I'm trying to pick up whatever info I can as well.
Oct 24, 2004, 05:02 PM
Ray's wings arrived already sheeted with balsa, so that step was handled for me.
Oct 24, 2004, 05:10 PM
The leading edge, tips and trailing edge is glued on with epoxy and sanded down. Doesn't take many words to explain, but it takes some time to do!
Oct 24, 2004, 05:20 PM
The wing after sanding.
Oct 24, 2004, 05:22 PM
It's not too early for bench flying is it?
Oct 24, 2004, 05:53 PM
It could happen...
InTheLift's Avatar
Looks menacing already! How about a all black paint scheme with a single red star on the vertical...ala Top Gun Russian "Migs"? I doubt it's a scale scheme, but for some reason, seeing that dark primered fuse...it just jumps out at me!
First flight of S&B Models ME-262, with a photo!! Jeremy_D Foamies (Kits) 10 Jul 29, 2002 04:45 AM
Check Out the S&B Models Me-262. All finished and ready to go!! Jeremy_D Foamies (Kits) 17 Jul 09, 2002 08:34 AM
Here it is, teaser pic of the S&B ME-262 Jeremy_D Foamies (Kits) 0 Jun 23, 2002 02:39 AM
S&b Me 262 kenny_dilger Foamies (Kits) 3 Apr 30, 2002 07:48 PM
me 262 ready to fly, motors /contr. f/s groundpilot Aircraft - Electric - Airplanes (FS/W) 2 Feb 25, 2002 01:33 PM
