module - Page 2 - RC Groups
Aug 28, 2017, 11:40 AM
MickeyMoo's Avatar
[QUOTE=JimDrew; If you can find a 2.1dbi 2.4GHz antenna, that will work fine. A 2.0dbi, 3.0dbi, etc. antenna will not work correctly. Also, the connector polarity has to be correct. You can't use SMA antenna when it needs to be a RP-SMA type.[/QUOTE]
I provided a link and a MPN for the antenna I purchased. The specs do comply with Jim's recommendation in his above post and I compared the performance to the original via a range test. The specs are listed in the link if you want to check them out.
Discussion Radio modules carrier signal and modulation camerart Radios 0 Sep 12, 2016 04:46 AM
Question New module for 9X, or new radio? Range of module JaySki35 Radios 19 Apr 27, 2016 08:13 PM
Discussion Fatshark Diverstiy Modules and LaforgeFPV Modules Question Taw198500 FPV Equipment 0 Dec 28, 2015 11:44 PM
Discussion Are there any 5.8Ghz 32CH FPV modules out there? Not the full TX, just the module? x0054 FPV Equipment 2 Oct 13, 2015 09:35 PM
Discussion Are there any 5.8Ghz 32CH FPV modules out there? Not the full TX, just the module? x0054 Mini Multirotor Drones 0 Oct 13, 2015 02:45 PM
