module - RC Groups
Jun 07, 2017, 09:48 AM
module
hi jim
i have a fu taba 9c with your extreme link module and there are 2 led that supose to light up when you turn on the tranny. but only the left led comes on.
so no signal. i got this from you at the toledo show. i put a futaba module in and it works. so do i have to send this in for repair.
buzz
Jun 07, 2017, 11:00 AM
What LEDs are you referring to... the ones on the 9C itself? If so, that is normal.
Jun 08, 2017, 10:17 AM
module
yes jim its the led on front of the tranny right side
can not use tranny
i have 15 of your receiver that i cant use.
help
buzz
Jun 08, 2017, 11:21 AM
That's odd because the module doesn't control the transmitter, it's the other way around. You can send in your transmitter module to check it out. If this is an original Toledo purchased module, you can exchange it for a new version with the external antenna.
Jun 10, 2017, 10:16 AM
jim
i sent in the module for the upgrade.
thanks for the quick comback.
buzz
7163662436
Jun 22, 2017, 09:46 AM
hi jim
what is the staus of the module i send in 2 weeks ago.
buzz
Jun 22, 2017, 10:58 AM
It was returned to you this week.
Jun 27, 2017, 08:34 AM
hi jim
thanks for the new module every thing works great.
thanks again
buzz
Jun 27, 2017, 02:13 PM
Glad to hear, you're welcome!
Aug 14, 2017, 04:30 PM
MickeyMoo's Avatar
I have two Futaba 9c radios and xps modules. Lately I've been playing around with some FPV gear and recently lost control of my wing <200m out. Thought it was the AIO 5.8 camera interfering but after some range testing I find its the antenna on one of the modules. One range tests ~90% better than the other. Swap antenna and its reverse. Jim, should I get the antenna off your web site or will any 2.4 antenna be acceptable?
Aug 16, 2017, 08:59 AM
MickeyMoo's Avatar
I tried an antenna from a Dlink 2.4 router and it didn't range test well. Reading some of the info on this site about antennae it sounds like one size does not fit all. Seems as though the antenna can be optimize to some extent for each application or circuit. I like to get my antenna replaced but sales are down till Sep. on Jim's site. Wish he would chime in here
Aug 20, 2017, 06:29 PM
Antennas are matched for our system. If you can find a 2.1dbi 2.4GHz antenna, that will work fine. A 2.0dbi, 3.0dbi, etc. antenna will not work correctly. Also, the connector polarity has to be correct. You can't use SMA antenna when it needs to be a RP-SMA type.
Aug 20, 2017, 09:25 PM
MickeyMoo's Avatar
Having some trouble finding an antenna Jim. I'll wait till you are open again in Sep. to order a replacement.
Aug 27, 2017, 04:44 PM
MickeyMoo's Avatar
Just to update this thread I bought this antenna...
http://www.ebay.com/itm/Digi-2-4ghz-...IAAOSwepJXU3uQ
The MPN is A24-HASM-450
It looks and seems to perform identical to the one that came with the XPS module.
Aug 28, 2017, 07:36 AM
Were you able to verify that the specs match what Jim provided to you ? Or are you just going to roll the dice ??
Discussion Radio modules carrier signal and modulation camerart Radios 0 Sep 12, 2016 04:46 AM
Question New module for 9X, or new radio? Range of module JaySki35 Radios 19 Apr 27, 2016 08:13 PM
Discussion Fatshark Diverstiy Modules and LaforgeFPV Modules Question Taw198500 FPV Equipment 0 Dec 28, 2015 11:44 PM
Discussion Are there any 5.8Ghz 32CH FPV modules out there? Not the full TX, just the module? x0054 FPV Equipment 2 Oct 13, 2015 09:35 PM
Discussion Are there any 5.8Ghz 32CH FPV modules out there? Not the full TX, just the module? x0054 Mini Multirotor Drones 0 Oct 13, 2015 02:45 PM
