I think I found a bug in A9X programmable mix menu - RC Groups
Jun 04, 2017, 10:12 AM
the_crack_fox's Avatar
After spending hours tonight trying to get a mix working on my A9X, I've come to the conclusion there is a bug in the firmware.
I have an aircraft stabilizer with a remote gain channel. I have set 2 flight modes. The mix is flat (disabled) in normal mode. I'm not using a switch to enable either mix.
In stabilized mode I want to mix the throttle with the gain channel to reduce the gain by about 30% at full throttle. I also want to mix another channel, operated with the RT trim switch to provide an offset that I can adjust in flight. I have used this method before on my old A9 and it works really well.
So I have...
THRO (J3, CH3) -> AUX1 (NULL, CH6) 30% downward slope, linear, offset to the top of the graph.
AUX4 (RT, CH9) -> AUX1 (NULL, CH6) 100% upward slope, linear.
Everything works great until I power down. When I power back up, the AUX4->AUX1 mix wont work. If I go into the mix menu and fiddle with it by adding or removing points on the line, or disabling / re-enabling a channel or input function, or deleting it and starting over I can get it to work again.
It would be good if someone else could try and replicate this. I think its time for a firmware update...
Jun 15, 2017, 09:40 AM
Xpress..'s Avatar
Sorry for the late response, I duplicated your mixes on a 9X here and was not able to duplicate the problem you are seeing, they have worked every time. I think the particular issue you are seeing is maybe there is something else enabled in that particular model memory that is causing a problem. My suggestion is to create a new model entirely and create the mixes inside of the new model to test- DO NOT COPY, you risk copying the problem into the new model.
Also make sure your Tx is updated to V 1.02(2).
Mini-HowTo equally separated 6 positions on DX7 using 1 mix, I think I've got the holy grail ChibiHeli Multirotor Drone Talk 0 Mar 21, 2016 06:31 AM
Discussion BUG: found on the latest firmware fopr NAZA-M V2 Sp1k3 DJI-Innovations 0 Sep 19, 2015 11:07 AM
Drop-down Menu Bug Miami Mike Site Chat 7 Jan 17, 2007 05:38 PM
Discussion BECs and programmable mix for brushless with 4-in-1 micros preston_brown Micro Helis 0 May 01, 2006 06:18 PM
Air Craft - Bug Found, Bug Squished NipponDave Vendor Talk 0 Jun 10, 2002 04:09 AM
