This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jun 03, 2017, 07:52 AM
FPV addict
mlilasic's Avatar
Mini-Review
Review of AKK 5.8G FPV 2000M Range TS832+RC832 & Mini CP Mushroom Antenna ML2
Review of:
AKK 5.8G FPV 2000M Range TS832+RC832 Audio Video Transmitter and Receiver for FPV Drone
AKK FPV 5.8G TX/RX 1pc SMA Male 1pc RP-SMA Male Mini Circular Polarized Mushroom Antenna ML2
My new package from AKK just came and, like last time, this time also was lightning fast delivery. Delivery to the Croatia took only 4 days.
I really can only highly recommended AKK in cases that you need quality FPV products at great price or in case that you, in a hurry, need parts to replace broken ones on your FPV craft, so you need them to be delivered quickly.
I will be talking about two AKK products this time:
  1. AKK 5.8G FPV 2000M Range TS832+RC832 Audio Video Transmitter and Receiver for FPV Drone
  2. AKK FPV 5.8G TX/RX 1pc SMA Male 1pc RP-SMA Male Mini Circular Polarized Mushroom Antenna ML2
Short description:
  • 40 Channel 600mW AV wireless receiver, designed for areas with too many frequencies in the air
  • It supports 5 bands and all frequencies compatible
  • Easily Change frequency channels and bands by pressing button
  • Double-screen display for channels and bands
  • It supports full range of 40 channels including raceband
Full Product Description:
Features:
40 Channel 5.8 GHz 600mW AV wireless transmitter and receiver set, designed for areas with too many frequencies in the air.
It supports 5 bands and all frequencies compatible. Easily Change frequency channels and bands by pressing button.
Double-screen display for channels and bands.
It is a Plug and play FPV transmitter and receiver set for Aerial Filming. Small size and light weight.
Specification for TS832 Transmitter:
This 5.8GHz 40CH FPV transmitter has double push buttons for easy changing CH and FR.
40 channels: Cover A, b, E, F, r bands
Video Format: NTSC/PAL
Output Impedance: 50 Ohm
Transmitting distance: > 3000m (open area)
Antenna connector: RP-SMA connector
Operating Voltage:7-16V
Supply current: 220 mA
Operating Temperature: -10 +85 ℃
Video Band Width: 0-8.0 MHz
Audio carrier Frequency: 6.5 MHz
Video Input Level: 0.8,1.0,1.2 Vp-p
Video Input Impedance: 75 Ohm
Audio Input Level: 0.5 ,2.0 Vp-p
Audio Input Impedance: 10K Ohm
Weight: 20g
Specification for RC832 Receiver:
Power Supply: DC 12V
Antenna impedance: 50
Video impedance: 75
Working Frequency: 5.8GHz
Available Channel: 40CH
Consumption Current: 200mA, Max
Antenna Gain: 2dbi
Antenna Connector: RP-SMA
Audio Carrier: 6.5MHz
Video Format : NTSC/PAL
Dimension: 80x65x15mm
Weight: 70g
In the Box:
1 x RC832 FPV Receiver
1 x TS832 FPV Transmitter
2 x Antenna
2x Power cable
1 x AV cable
1 x User manual
Short description:
  • Frequency Range:5.8GHz
  • Connector:1pc SMA 1pc RP-SMA
  • Gain:5dBI, Max Power:50W
  • Polarization:Circular polarization
  • 5.8 GHz Circular Polarized Antenna Set for transmitter and receiver
Electrical Specifications:
Product Type:Mushroom antenna
Impedance:50Ω
VSWR:<1.5:1
Gain:5dBI
Polarization:Circular polarization (LHCP)
Levorotatory
Max Power:50W
Height:423mm
Max diameter:35mm
Min diameter:35mm
Connector:SMA
Connector:RP-SMA
Lighting Protection:DC Grounded
Weight: 12g
In the box:
1 x 5.8G SMA Antenna
1 x 5.8G RP-SMA Antenna
Combo VTX and antenna weight: 33g
TODO:
  • DVR flight footage
For other AKK products please visit AKK WEB shop:
https://goo.gl/rUqnWF
Jun 03, 2017, 07:57 AM
FPV addict
mlilasic's Avatar
On the ground:
1. Eachine VR006 - https://goo.gl/jr1x3V
2. FXT MARVEL Vision Version II - https://goo.gl/d6PL7D
with: Realacc 4 Leaf Antenna - https://goo.gl/Z1rSZD
and Aomway 11dbi Helical Antenna - https://goo.gl/hQooth
In the air:
X16 RTF GPS quad - https://goo.gl/te4dQn
Aomway 1/3 CCD 650TVL - https://goo.gl/ndUC5f
AKK 600 mW VTX - https://goo.gl/ETPYJY
AKK antenna - https://goo.gl/Gq894Z
Eachine VR006 vs. FXT MARVEL Vision Version II - 1km range test (3 min 32 sec)
Jun 03, 2017, 07:59 AM
FPV addict
mlilasic's Avatar
X16 gimbal mod bench test:
X16 gimbal mod (1 min 16 sec)
Jun 03, 2017, 08:02 AM
FPV addict
mlilasic's Avatar
Short test flight after which I lost the prop nut
RunCam3 on Bayangtoys X16 - HD cam "Born for RC Fanatics" (1 min 27 sec)
I took the props off to swap them for spare set as I was getting a lot of vibrations and in that process I lost the nut.
Discussion AKK Tecnology - FPV 5.8G TX/RX Mini Circular Polarized Mushroom Antenna set Datos FPV Equipment 4 Apr 28, 2017 03:57 AM
