Looking for a cheap capable slope wing? - Page 2 - RC Groups
Aug 19, 2017, 08:02 PM
flyin' fool
goldguy's Avatar
Just got two more 800 V1 for $17 CDN each to my door.
Gonna build this ....................
Aug 21, 2017, 02:36 PM
CG clarification
Hi Frank,
Thanks for your help getting me started on this glider!
From your post #7 about the CG location, you say: Balanced 1/8" in front of the back spar ...
From Post #1 second photo, are you referring to the back spar on the bottom of the plane that apparently is installed per the kit instructions or factory installed? Photos in Post 1 appear to show 3 short spars on the top and 2 short spars on the bottom.
I ordered one RW 800 for $16 US from the BG US warehouse.
https://www.banggood.com/DW-HOBBY-Ra...content=227736
I also ordered some HXT500 6.2 gram servos on eBay, $5.59 ea, free shipping, since HK USA West in Portland was out of stock.
http://www.ebay.com/itm/New-Hextrini...%257Ciid%253A1
I plan to use my existing E-Flite 500 mAh 1S 3.7V 25C Lipo battery. I've used this on two other home-made gliders with sucess.
https://www.bhphotovideo.com/bnh/con...=Y&sku=1039792
I'll use my existing Lemon Rx, 6 channel, DSM2 compatible, with end pins $8.50 ea
http://www.lemon-rx.com/index.php?ro...&product_id=92
Aug 21, 2017, 11:13 PM
flyin' fool
goldguy's Avatar
The blue dots (plastic round pin heads) in front of the rear spar is the starting spot for the CG.
Aug 21, 2017, 11:16 PM
flyin' fool
goldguy's Avatar
On 1S the servos are going to be a bit lazy.
Aug 21, 2017, 11:28 PM
NiMH Battery Source
Thanks Frank! Lazy servos don't sound very good.
Where do you get your 4 cell NiMH battery packs, specifically the 220 mAh 2/3 sub C 4 cell NiMh battery pack you used in the RW 800?
I found two options on the Horizon Hobby web site ... they cost almost as much as the airframe.
https://www.horizonhobby.com/content/battery-finder/
The Losi battery is $12.49, but the white connector looks unusual, so I may have to solder on a servo connector that allows plugging the battery into the Rx. https://www.horizonhobby.com/LOSB0878
I just bought one of the Losi batteries on Amazon for $13.81 with free shipping
https://www.amazon.com/dp/B002OPPR7K...9ebavq3i_b_p20
rcflydad
Aug 22, 2017, 12:45 AM
flyin' fool
goldguy's Avatar
That's what I'm using, the Losi. Have had a couple in service for a few years with no problems, so just got two more. Will change the plus since I use this charge/on/off method................
Discussion Looking for a cheap FPV flying wing Cary Pond Flying Wings 10 Jun 07, 2016 12:56 PM
Discussion Looking for airfoil advice for fast slope soaring wing EarthMagnet The Builders Workshop 6 Apr 23, 2013 06:44 PM
Discussion Looking for a faster slope wing. considering M60 bikeman Flying Wings 7 Jan 12, 2006 06:25 PM
Looking for a cheap lithium capable ESC for speed 400 use... papasmurf Power Systems 5 Apr 24, 2004 10:38 PM
Looking for Plans for a Slope Soaring Racing Wing Purple Baron The Builders Workshop 0 Feb 28, 2004 03:37 PM
