Jun 01, 2017, 03:55 PM
flyin' fool
goldguy's Avatar
Looking for a cheap capable slope wing?
Check out the Rainbow 800mm wing from BangGood. At 6 ounces mine has good energy retention and excels at aerobatics.
https://www.banggood.com/DW-HOBBY-Ra...l?rmmds=search
Jun 01, 2017, 11:15 PM
Closed Account
/.,m
Jun 02, 2017, 02:26 AM
flyin' fool
goldguy's Avatar
Note in the picture of the bottom I have melted in two launch finger holes with a big washer and a 30W solder iron. That flimsy ply spine/skid on the bottom is useless.
You could SAL a slope wing if it has the proper vert. stab, like the Alula, with as much area above as below the wing center line.
I added a scrap of EPP to the TE where the motor was, a cover for the electronics bits, weed whacker/brush cutter line to the leading edge and nylon strapping tape as a bottom skid. Oh, and push rods perpendicular to the hinge line
Jun 02, 2017, 06:53 AM
Closed Account
bvz
Jun 11, 2017, 05:46 PM
SloMo_FPV
What are you using for a battery setup? Where do you have the battery located fore/aft? And where does it balance and is that the correct position for the cg??
Jun 11, 2017, 09:22 PM
Closed Account
'lk
Jun 12, 2017, 12:50 AM
flyin' fool
goldguy's Avatar
A 220 mAh 2/3 sub C 4 cells NiMh battery and balanced 1/8" in front of the back spar with about 3/16 reflex in the elevens.
Jun 12, 2017, 12:52 AM
flyin' fool
goldguy's Avatar
Got the 1000 as a tester from BG. Gonna slope it too. Slooowly getting it ready.
Jun 12, 2017, 08:28 AM
Closed Account
65w4
Jun 12, 2017, 08:54 AM
Closed Account
;lkh
Jun 12, 2017, 09:47 PM
flyin' fool
goldguy's Avatar
I'm an *armchair cowboy and a Hopalong Cassidy fan. Have been for over 7 decades and am lucky enough to watch him about four time a week on cable TV. Seen all 66 movies over and over again, and still get that urge to fling my popcorn box at the screen when the bad guys get the upper hand.
* horses have been a big part of my family................. and I'm allergic to the critters.
Jun 13, 2017, 01:23 PM
Pass me that hammer...........
pardshaw's Avatar
Hey Frank....
..... the Fluteboy is cheap and capable. You have to roll your own, though. Made from 3mm Corex. I made one yesterday. Flew it today. Nice.
Here's a thread where I've posted a couple of details:
https://www.rcgroups.com/forums/show...r#post37719250
Dave
Aug 18, 2017, 03:24 PM
More details please
Hi Frank,
This RB 800 looks easier than getting started sloping with than a Wisel or your Boomer Jr and has your stamp of approval. I've been swamped with OT this year at work until recently, so I've made little progress on gliders this year.
What servos do you use? is it this one you listed in the Boomer Jr. thread? https://www.hobbyking.com/hobbyking/s...0sec_5_6g.html
What 4 Channel Orange Rx do you use?
What laminate thickness? If the 1.7 mil used in the Boomer Jr, where do you get it?
What are your recommended c.g., throws, expo, etc.
How is the RB 1000 coming? Do you use the same gear, or do you upgrade the servos and battery?
What are your setup info for the RB1000, including your recommended c.g., throws, expo, etc.
Is it possible to clean off the graphics with alcohol or do you have another suggestion?
rcflydad
Aug 19, 2017, 07:51 PM
flyin' fool
goldguy's Avatar
With the RW 800 I kept it simple for an easy and quick 'ready to fly' build.
I added two CF short spars to the top center, a piece of foam across the motor cutout, weed whacker line to the LE, a lid for the gear and a bit of black acrylic paint. No lam film or tape, it's rigid enough. The control is done by an Orange R410X, two HXT500 servos. The rest in post #7.
I don't use dual rates or expo. My brain and thumbs are my computer program, even though I have the DX6G2
Aug 19, 2017, 08:00 PM
flyin' fool
goldguy's Avatar
The 1000 is another story. Built as kitted, it's floppy. Working on it now. Not sure if I'm going to make it a pure sloper or make it into a tractor power for both the slope and at the field. I think it would make a fun thermal machine, because we get lots of boomers where we now fly and I don't have a glider.
The paint can be removed with alcohol, but lacquer thinner does a better job. An old pint brush works the best............... outdoors.
Discussion Looking for a cheap FPV flying wing Cary Pond Flying Wings 10 Jun 07, 2016 12:56 PM
Discussion Looking for airfoil advice for fast slope soaring wing EarthMagnet The Builders Workshop 6 Apr 23, 2013 06:44 PM
Discussion Looking for a faster slope wing. considering M60 bikeman Flying Wings 7 Jan 12, 2006 07:25 PM
Looking for a cheap lithium capable ESC for speed 400 use... papasmurf Power Systems 5 Apr 24, 2004 10:38 PM
Looking for Plans for a Slope Soaring Racing Wing Purple Baron The Builders Workshop 0 Feb 28, 2004 04:37 PM
