This thread is privately moderated by AlkaM, who may elect to delete unwanted replies.
Jun 01, 2017, 12:38 PM
Mini-HowTo
Another strange BlHeli_S 1-3s DIY esc
This is a very simple esc to build. It actually uses P-fets for the upper switch and switches them through a voltage divider. The bottom n-fet is driven directly from the MCU. I have tested it in a quad on 2s and 3s and on the bench with 1s ( don't have a 1s flight controller to test with). It didn't even explode on 4s with a racerstar 1306 motor !( but most likely would in the air or the motor would smoke). It can't give a current rating but it will be fine for the smaller motors up to 15 amp burst. In practice the motor got much hotter than the esc's for the 1306's.
It's tricky to get the bridge to switch fast enough so the resistor and component choices are critical. There are only a handful mosfets that I know of that would work on the pcb at that switching speed with such poor drive current. Also the pinout for the p-mosfet is different from the norm so look at the parts notes on the schematic carefully if you want to build this. The layout is a for a four layer board but the schematic is pretty basic to make a two layer version.
Uses firmware F_H_90.
Gerber files and schematics and layout in the zip.
Upper mosfet p-channel : CSD25402Q3
Lower mosfet n_channel: CSD17304Q3
Oct 10, 2017, 11:28 AM
Hi,
i've written you via mail, but you don't seem to answer.
Is there a way to get in contact with you?
Dec 14, 2017, 12:29 PM
Originally Posted by Tschones FPV
Hi,
Sorry, I never saw this, I didn't get any mail in my inbox from you either. I hope you got it sorted but if you have any questions you can contact me through the blog itself and i'll check every so often.
Help! 4 in 1 ESC strange drop-throttle response? kenkamm Multirotor Drone Electronics 6 Feb 11, 2018 01:27 AM
New Product Favourite FVT LittleBee Spring 6A & 10AŚ4 Blheli_S 2-3S 20x20 ESCs sevet Multirotor Drone Electronics 1 Jul 14, 2017 08:48 PM
Discussion Maytech BLHeli_S ESC programmer, 4 in1 BLheli_S ESC MaytechRC Multirotor Drone Electronics 27 Nov 29, 2016 07:20 AM
Discussion Why are my ESC's limited to 2-3s instead of 1-10s? Intentional ESC Abuse. nerobro Mini Multirotor Drones 0 Oct 21, 2015 09:32 AM
