TF Monokote Trim Solvent
This stuff does work, no doubt.
I can't help but to think there are other possible alternatives though. I have toluene, xylene, acetone, MEK, denatured alcohol, paint thinner and lacquer thinner to work with. Anyone have any experience with making a solvent or two get the job done vs. buying name brand stuff? Thanks in advance for your feedback! |
I always either iron the trim down, or use the Windex. I definitely use the trim-solvent to go over edges and clean up any bleeding... and it tends to further seal the edges when applied sparingly. Trim-solvent cleans an iron like no other as well.
I'm also curious if there's another alternative as well... as I don't have that answer... but I definitely use trim-solvent. I go through a bottle of trim-solvent about every 5yrs.. so I'm not really in the market for other chemicals, but I am curious. I covered these with iron-on Monokote, graphics, stripes, and trim all hand cut. |
I'll break out some various coverings soon and give it a look with a few solvents. Seems like I remember acetone doing some good, toluene and xylene look promising as well, lacquer thinner and MEK have potential, too. All of these are fairly 'hot' solvents...one of them is bound to work! BTW...the plane with the flag looks excellent! ...Good Job! |
I have used carb cleaner and brake cleaner. A little spray, position the piece, squeegee down, let dry.
I have also sprayed the trim on ARF's to seal the edges. Buzz. |
ALL of these comments/pictures are quite helpful to a lot of guys out there...great stuff!
A whole different topic though...T/F Monokote produces gases when heated, especially when you go hot...how do you keep bubbles from forming when 'customizing' over another layer? ...in my experience, other coverings don't 'bubble' as bad...Ultracote does really well. Now, if I will just get off of............ and see which solvent DOES work. ...possibly tomorrow I will do a few experiments, will see! |
For me layering is never as perfect as I like. The Windex method helps quite a bit, along with squeegeeing the film well before the heat is applied.. and using the lowest heat that just tacks the film down seems to help as well... and once bubbles are worked out better, then just adding a bit more heat and going over it again.
I use either a credit card, biz card, or even a cotton pad is good for sensitive film..all depends there, but I get it layed down as much as I can. If I end up with bubbles, I use the sharpest needle I can find in my wifes sewing room(even then I sharpen it(yes, I sharpen needles..).. and just try to prick/pierce the bubble as gently as possible... that works decently. Again, its never absolutely perfect, but when the plane goes by at 100mph I'm not thinking about bubbles... ![]() Striping is actually very easy... up to about 1/2"... I like to cut and iron on my own stripes... It's so cheap... a plane can be striped very nicely for about a bucks worth of film if that... as well as shapes and smallish graphics are fun too... but the bigger the graphic, the more chance of bubbling of course. The above does give reasonably good results for me though. |
I just tried some MEK as a trim solvent. I was applying a 6X5 piece of Monokote on the bottom of a wing. It works but leaves bubbles. Maybe they will go away after some time.
First test I used a foam brush and brushed on a generous coat as it evaporates VERY fast. That made a huge mess. Pealed it off and cleaned up the left over glue. That was a mess also. ![]() ![]() ![]() Ken |
Monokote solvent works better than anything I've tried. Yes, its pricy and it stinks to high heaven but it does work. One feature of it that I like is that it doesn't seem to degrade the heat activated adhesive on the Monokote. Some of the others mentioned will dissolve that adhesive and keeps the covering from sticking as good as it should. But as with everything else with this hobby, you need to use what works best 'for you'.
Tom |
Thread Tools | |
Similar Threads | |||||
Discussion | Trimming with Ultracoat What solvent to use | kenh3497 | Fuel Plane Talk | 22 | Mar 19, 2017 09:51 PM |
Question | trim solvent | Flyzzzz | Painting and Finishing Tips | 4 | Aug 30, 2016 10:49 PM |
Discussion | Monokote Trim Solvent | glew | The Builders Workshop | 0 | Jan 17, 2015 11:19 PM |
Discussion | HELP with MONOKOTE TRIM SOLVENT!! | RCRoger2001 | Fuel Plane Talk | 5 | Aug 29, 2012 05:09 PM |
Monokote and Trim Solvent | billrcpilot | Fuel Plane Talk | 2 | Jan 12, 2005 03:07 AM |
