plane still not level after setting flat level mounting? - RC Groups
May 29, 2017, 10:06 PM
Hi all,
I am flying with the Vector for almost a year, but there still things I cannot manage to figure out how to do.
Before flying, I lay my plane on the ground, level, and do the 'setting flat level mounting' as described in the manual. My sticks are at zero trim. But even then, in the air, at 2D no-hold mode, the plane is not stable and banks to one side all the time.
When I switch to RTH, the Vector fly it perfectly, stable, level and everything.
Why is that? Why the 2D mode cannot produce a level flight, while the Vector is capable to do it, as can be seem in the RTH mode?
I don't want to use the trims, because it might cause the RTH not to be engaged, and because I prefers using the trims for the manual mode. Am I correct with that? I did saw videos that explain how to trim the plane in manual mode (during flight), and the todo 'incorporate trims', so the won't mess up the 2D mode. So I figured out that the trims are to be used on the manual mode only?
Am I missing something something in the preparation process?
Thank you in advance,
Tal
May 30, 2017, 03:23 AM
because rust never sleeps....
HugoRogers's Avatar
Originally Posted by Talsharf
Hi all,
Tal
The flight controller needs to know what your stick input values are when you are hands off. If you adjust the trim this looks to the flight controller like stick input and so it will change its attitude accordingly in stabilised mode. What you need to do whenever you adjust the trim is "Incorporate Trim" values from the menu, this is possible to do in flight, although not particularly convenient from a user experience point of view.
May 30, 2017, 08:27 PM
Hi Hugo,
Thank you for your reply.
I think I got it now.
So, I can fly in manual mode, do some trims, then do incorporate trims. Then this is considered by the vector as the 'hands off' values, so when I go into stabilized mode, it should be level, and also in manual mode, right?
Cheers,
Tal
May 31, 2017, 04:39 AM
HugoRogers's Avatar
Hi Hugo,
Cheers,
Tal
Correct.
Jun 01, 2017, 11:27 PM
Million thanks Hugo ;-)
Help! Self leveling is not leveling correctly in Angle and Horizon Modes Betaflight. tablab1 Beginner Multirotor Drones 28 Dec 20, 2017 05:14 AM
Discussion Still Not A Bro, Still Not A Russian Agent, Still Glad Hillary Lost kenpoprofessor Life, The Universe, and Politics 1 Apr 06, 2017 06:44 AM
Data Flat Foam 32" Plane Set up krisvanjr 3D Foamies 15 Mar 22, 2016 08:57 PM
Complaint After changed name poster is still referring to me not by my name erh7771 Site Suggestions / Complaints 2 Aug 26, 2014 11:00 PM
Logo 10 Still setting it up after 2 months! Lv2Fly Electric Heli Talk 22 Oct 07, 2002 07:20 PM
