"Taylor II" Case Status Updates (only) - RC Groups
This thread is privately moderated by JohnATaylor, who may elect to delete unwanted replies.
May 29, 2017, 11:56 AM
Announce
This thread will be used for case updates only.
Discussion, which is certainly welcome, should take place in other threads. Thanks.
Here are the significant documents from the “Taylor II” case. The case challenges the FAA’s authority to create 14 C.F.R. 101.41, and the inclusion of all non-336 conforming activities within Part 107 - which requires testing and licensure, and is generally considered applicable to commercial operations.
It raises many of the same issues as the Taylor I case regarding whether model aircraft are properly “aircraft” under our statutory and regulatory scheme, whether the FAA has legislative authority to regulate low-altitude activities that don’t directly affect the traditional navigable airspace. It also challenges whether the FAA has acted arbitrarily and capriciously in adopting regulations which, in context with other existing laws, simply don’t make sense.
The Regulation:
https://www.gpo.gov/fdsys/pkg/FR-201...2016-15079.pdf
Taylor Brief:
http://bit.ly/2lhtjwQ
FAA Brief:
http://bit.ly/2qgooAl
Taylor Reply Brief:
http://bit.ly/2qeYVHo
The Reply Brief was filed on May 12, 2017. Based on the timing of other cases, I would expect that in October, the court will set it for oral argument in December. Of course, with the FAA reauthorization before Congress this summer, the case could be derailed by legislative action.
Again, please do not post comments, etc. in this thread, but feel free to post them elsewhere.
Thanks.
Nov 08, 2017, 06:29 PM
This case has been scheduled for oral argument on January 25, 2018.
Jan 25, 2018, 03:08 PM
I argued the “Taylor II” case today before a three-judge panel of the U.S. Court of Appeals for the D.C. Circuit, consisting of Judge Merrick Garland (Obama’s Supreme Court nominee) and two senior judges.
The case challenges the FAA bringing model aircraft under Part 101, and the vagueness/reasonableness of the standards to distinguish the need for hobbyists to comply with Part 107.
Key to my argument was the fact that Sec. 336 does not, itself, create duties of hobbyists. It only creates limitations on FAA authority. Within that authority, the FAA must still adopt regulations that are clear enough to be followed, and not arbitrary or capricious.
I argued that the CBO criteria in 336/101.41 are not clear enough for people to understand what is expected of them, and the FAA itself has said that the airport notification requirement creates a burden on airports, with no real benefit.
The FAA, in the rulemaking, acknowledged those are legitimate concerns raised by commenters, but deferred addressing them until some future time.
Agencies are required to consider relevant materials during the rulemaking process. They can’t simply defer reasoned decision making to some point down the road after the rule is adopted.
I had a great deal of difficulty convincing the court that while Sec. 336 is only a limitation on regulation, Part 101/107 creates new affirmative duties.
As oral argument in my first case leaned heavily in my favor, I think it’s clear this one leans heavily, probably more so, in the FAA’s favor. We’ll see.
I gave it my best. These issues are a marathon, not a sprint.
For a little light reading, here are the briefs:
Taylor Brief: http://bit.ly/2lhtjwQ
FAA Brief: http://bit.ly/2qgooAl
Taylor Reply Brief: http://bit.ly/2qeYVHo
Here’s the audio. My part starts at around 0:21:08 (a privacy-oriented organization filed a separate and unrelated petition); my rebuttal starts at 1:03:00:
https://www.cadc.uscourts.gov/recordings/recordings2018.nsf/3FCAC8D99D6DB1F7852582200063E4EB/$file/16-1297.mp3
My audio drops out for a while at one point for a while.
Jan 25, 2018, 07:13 PM
Fire Marshall Bill
Go get em John
Jan 26, 2018, 01:20 PM
Commander, U.S. Navy (Ret.)
franklin_m's Avatar
John, any thoughts on possibility the court will at least shed some clarity on "...and within the programming?" I listened to your argument, and it seemed like it would have been easy to say "for example, does it mean you have to be a member?" Any reason why you didn't use that?
Jan 26, 2018, 10:30 PM
My goal was to demonstrate that it wasn’t reasonably clear (and thus unlawful), rather than to get the court to find, or impose, clarity.
I’m confident they would have dodged the membership question, same as they dodged the “within the programming” question.
I threw the latter out there, knowing they couldn’t answer it, simply to dominstrate it isn’t reasonably clear.
Announce "Taylor I" Case Status Updates (only) JohnATaylor Model Aircraft & Drone Advocacy 2 Jul 03, 2017 01:41 PM
Discussion Taylor v. FAA Update JohnATaylor Model Aircraft & Drone Advocacy 1399 May 29, 2017 11:54 AM
