I can see that...though it does explain why people coming here for what should be relatively straightforward advice end up getting so confused. Steve |
I like to run mine totally flat, then fully charge them when I get home and leave them in a cardboard box until next weekend.
Latest blog entry: Park pattern/pylon perfection!
Thanks all.
My charger does show the voltage per pack (which is why the 12.6V number is known). I have read enough on LiPos to know that flattening them kills the chemistry - I meant cycling from 9V to 12.6V but I think the general consensus there was a solid "no". I think my safest bet is, as people have pointed out, to get a voltage alarm - hoping my LHS has a few. My Tx is telemetry capable just my Rx is not. -_- |
Oh ya, and when you need to discharge a battery be sure to take note so that when you go to charge a battery, the charger is set back to CHARGE.!!!
Ask me how I know.... I have a 6cell battery that is about a year old. I meant to charge it but my charger, a day earlier, discharged a battery that I didn't fly. So, I thought I was charging for about 15 or twenty minutes when I realized I was DIS-CHARGING. The first cell was at 3.62v. After a flight on that battery the other 5 ells were at about 3.8v but that first cell was at 3.64v. Is it toast.?? |
In discharge mode a 'reputable' charger -might- have stopped the process at 3.6. Check the manual about that. It might even be adjustable. |
Thread Tools | |
Similar Threads | |||||
A question regarding mah, voltage, and flight time. | Greasydugan | Batteries and Chargers | 11 | Apr 13, 2014 07:48 AM | |
Whats more important for lipo health: Voltage or amount of mah put back after flight? | conezone | Batteries and Chargers | 4 | Sep 23, 2011 04:06 AM | |
Question | Will I lose flight time with a higher cell count/voltage, lower mah battery? | 3dVector | Electric Power Systems | 7 | Oct 23, 2010 01:51 PM |
ok so ist it 80% of the voltage or 80% of the mah to set flight time by??? | nashiem | Batteries and Chargers | 4 | Sep 06, 2007 08:44 PM | |
Discussion | Blade CP flight times? Stock battery vs. 860 mAh lipo and AEK | flyingace451 | Micro Helis | 5 | Jun 20, 2006 07:17 AM |
