May 26, 2017, 01:04 PM
Help!
F16 jet pusher big size..
Hello,
I am planning to build a pusher F16 a big size plane about 85 inches long & 55 inches wingspan, plan to build it very very light weight I do not plan to fy it fasst... any suggestions what motor & battery would be good for this size ultra light plane.. thanks in advance
Jun 21, 2017, 09:26 PM
My F16 pusher is 60" long.
I run a Scorpion SII-3026-1190 kv motor on 5000 4s 65C batteries and a 12x7 prop running around 950W. The plane hand launches and has better than 1:1 thrust to weight.
I'm working on a 72" long f18 and am looking at moving to 6S 5000 battery/motor combo for somewhere closer to 1300W.
Mar 27, 2019, 12:41 AM
please post a photo
Mar 30, 2019, 01:37 PM
Here are some current pictures.
Just finishing up some winter upgrades:
- Changed the control rods for the elevators to carbon rod.
- 3D printed the exhaust nozzle
- Strenghtened the motor mount
- added more carbon tow around the canopy/battery opening
I strongly suggest you invest in the Carbon Tow.
My F16 is all foam with 3/4 oz FG and polyurathane covering. Carbon Tow running over top and around the canopy.
No wood or carbon rod bracing in the fuse. I can hold the plane horizontally by the nose and it doesn't flex.
Currenly at the fill/sand/fill/sand/prime/fill/sand/fill/sand/prime stage
Gery
Mar 30, 2019, 01:49 PM
Here's the F18. Working on the wings.
Included side-by-side with the f16
Mar 30, 2019, 02:13 PM
In the picture it looks like the F-18 is built using the "cross-section stacking" method of foam scratch building - where did you get plans showing all of the fuselage sections to make templates for cutting the parts to make the fuselage? Other than using a CAD program I don't know a way of coming up with them accurately, and I really like building that way.
Mar 30, 2019, 05:53 PM
For the F18, I found a half decent model on grabcad.
Since I couldnít modify the model, I Sectioned it and built my own surfaces. Then I modified the model to adjust for making It an rc plane.
Now I can do whatever I want with it. Scale up or down.
I have an old thread here somewhere for the f18. Didnít seem like anyone was interested in it so, I stopped posting.
Mar 30, 2019, 05:59 PM
If you want more info on the f18, click on my name and look at the threads I started. Youíll find the F18 there.
Apr 01, 2019, 01:01 AM
edwen303's Avatar
Been in EDF world for long but really like the efficiency of pusher jets. Been running Hobbyking motors for a decade and almost never had problems with them, and they are cheap and have the job done!!!
This motor with ~10' prop might be a good setup:
https://hobbyking.com/en_us/propdriv...B&gclsrc=aw.ds
Here are all the motors you might be interested, just stay away from those heli motors:
https://hobbyking.com/en_us/power-sy...wer_w=597-2149
Would try 6s on this motor myself, with smaller prop like 8' or 9'. ESC on hobbyking has good price too, here is one:
Apr 01, 2019, 01:07 AM
edwen303's Avatar
All the ESC you might need: https://hobbyking.com/en_us/power-sy...lity_type=4564
I would go with >100A ESC for peace of mind. You can easily unplug from one model to power another model.
Apr 02, 2019, 12:12 PM
great going...
May 12, 2019, 09:55 AM
Hey Harry. How are things going with the f16?
Discussion i have a pusher jet f16 fiberglass fuse sherlockshah Power Systems 3 Mar 30, 2019 02:22 PM
Discussion want to sell my pusher or edf convert f16 sherlockshah Pusher Prop Jet Models 1 Oct 02, 2015 10:16 PM
Discussion F16 Ultrafly Pusher Jet Charles61 Power Systems 0 Mar 05, 2012 09:38 PM
Discussion UltraFly F16 Pusher Jet Charles61 Foamies (Kits) 0 Mar 03, 2012 04:30 PM
Discussion Ultrafly F16 Foam Jet Pushers... Airwolf57 Pusher Prop Jet Models 7 Mar 05, 2010 12:00 AM
