May 26, 2017, 03:57 AM
No RTF flies like your own SB
mperaltaoz's Avatar
Build Log
Hall Bulldog Racer 1200mm
Hi All,
I've been quite busy lately and didn't get around building anything new, until now!
I saw this model in the Aerofred newsletter and I instantly fell in love with it.
I've started with the plans in Sketchup as usual, using a nice image of the 3-views as a reference.
Specs:
Wingspan: 1200mm
Wing area: 18 dm2
Weight: 1.2-1.5kg
Motor: Turnigy D3536 790Kv 715W
Prop: Wooden 13x6
(same power train as my Edge 540 V3 which is a powerful beast!)
Battery: 2200mAh 4S
May 26, 2017, 08:24 PM
crankster's Avatar
Mario, you're a legend. What a ripper model. Keep the pics coming as you build
May 26, 2017, 08:30 PM
crankster's Avatar
Are you planning to hotwire the wings? If so, how would you build the shape?
May 26, 2017, 08:35 PM
mperaltaoz's Avatar
Yes, Darren.
I'll hotwire them in sections and hold them together with a plywood spar.
Pretty much in the same way I did the Corsair.
May 26, 2017, 08:42 PM
crankster's Avatar
figured that would be the way. So wing sections. Cut through at the longest point on the trailing edge. Nice work. What foam are you going to use? The yellow bunnings stuff?
May 27, 2017, 01:51 AM
mperaltaoz's Avatar
Yes.
Started work today, cut the wing blocks and the inner top sections.
Note that I'm using aluminium flashing for the formers and ribs.
It works much better than cardboard allowing smoother cuts.
Thanks for the tip, Darren!
May 27, 2017, 09:16 AM
Very cool plane looking forward to watching it come together.
May 28, 2017, 06:17 AM
mperaltaoz's Avatar
I've cut all the wing sections now. Next step will be fuselage sections.
May 30, 2017, 03:28 AM
mperaltaoz's Avatar
Hotwired the cowl and prepared blocks for the mid fuse section
May 31, 2017, 07:00 AM
mperaltaoz's Avatar
And now we've got al the fuselage sections done!
Next step will be sanding and gluing
May 31, 2017, 07:59 AM
When cows fly!
May 31, 2017, 08:05 AM
crankster's Avatar
Amazing work. you should do a video showing how you work the hotwire on those tapered fuselage sections. This is coming together very nicely
Jun 03, 2017, 05:14 AM
mperaltaoz's Avatar
Alright, got all the parts sanded over the last couple of days and I glued everything today. Hopefully the photos will give a clear indication on how the parts were glued together.
Jun 03, 2017, 06:05 AM
crankster's Avatar
Great pics. Making more sense now. I can see how you glue the blocks to give the rough shape then hotwire the final using the template. Clever.
The masking tape is to stop the PU from expanding out and making a mess ??
Mate, you wife must be pretty cool to let you work on the dining table
Jun 03, 2017, 06:16 AM
mperaltaoz's Avatar
Hahaha... yes she's got used now
I typically do this in my workbench in the garage but it's full of other stuff at the moment.
Yes the tape is for the polyurethane not to foam out.
Discussion Hall Springfield Bulldog - 1930's Air Racer localfiend 3D Printed Planes 62 Aug 12, 2017 01:24 PM
Discussion Dumas Hall's Bulldog build Phil_Ford Balsa Builders 7 Aug 07, 2017 09:00 PM
Discussion Hall Bulldog Racer Old Gearhead Vintage & Old-Timer Designs 5 Sep 06, 2010 12:29 PM
Hall Bulldog plans wanted shovelheadfreak The Builders Workshop 3 Jul 19, 2005 06:11 PM
hall bulldog jwz357 Scale Fuel Planes 2 Nov 06, 2003 02:34 PM
