Flash 7 and PPM - RC Groups
May 24, 2017, 10:36 PM
Flash 7 and PPM
Can someone confirm if the flash 7 supports any PPM, thanks
May 25, 2017, 12:01 PM
Xpress..'s Avatar
Can you clarify what the exact application is?
May 25, 2017, 06:45 PM
I'm using a little AFHSS compatible (not made by hitec) reciever on a qx90 micro quad. Have to connect it to an F3 brushed controller, which has a pin connections or DSM/DSMX or PPM inputs. I know the reciever will put out a PPM signal but wasn't sure if the transmitter would work with the setup, or is the PPM just on the output side of the reciever and just works as normal on the tx link side?
May 26, 2017, 11:27 AM
Xpress..'s Avatar
The PPM output is just on the Rx side, just link the transmitter to the receiver and you should be good to go.
May 26, 2017, 08:19 PM
Thanks, after some mucking around it all work well.
Help! Hitec Flash 7 jrf2 Radios 2 Oct 27, 2016 11:30 AM
Discussion Futaba 6K / 6J vs. Hitec Flash 7 Dparture Radios 8 Feb 01, 2016 08:47 AM
Discussion Hitec Flash 7 and Flash 8 Xpress.. Radios 1 Jun 12, 2014 07:50 PM
Discussion Flashed ER9x firmware and now ezUHF not detecting PPM at startup bauerbach FPV Talk 3 Apr 12, 2013 12:35 AM
Discussion Need help flashing besc with Quax ppm code rjwims DIY Electronics 2 Aug 30, 2010 10:04 PM
