HPP-22 "radio plug" wiring - RC Groups
May 23, 2017, 12:44 PM
All Thumbs
Ranald's Avatar
Question
Hi guys,
Does anyone have a connection / "pinout" diagram for the HPP-22 radio plug?
I have an HPP-22 Programmer Interface, but no cable with the stereo (three conductor) plug for the Aurora 9X.
I have a spare servo cable (or ten) on the shelf and a few stereo plugs in a box...
i.e. does (yellow - red - black) map to (tip - center - shield end)?
Of course, if you happen to have one, and you have an ohm meter handy, I'd appreciate the intel...
Thanks!!
Ran
UPDATE:
GOT IT!! MANY THANKS!!
WRONG: [Also: The "radio plug" w/ the stereo jack appears not to be needed for the A-9X when using the HPP-22 IF. On the back of the Tx there is a separate 'DATA' plug w/ a regular three-pin arrangement. All that is needed is a MALE - MALE cable.] Sorry 'bout that. Corrected by Xpress below - Thanks!
Cheers! - R
May 24, 2017, 11:41 AM
Xpress..'s Avatar
The Aurora 9X needs both the stereo jack and the servo plug style cables to update it. The DATA port is strictly for updating the Spectra module, you can't update the transmitters main board itself through the DATA port.
Aug 03, 2017, 11:46 AM
All Thumbs
Ranald's Avatar
https://www.rcgroups.com/forums/show...9#post19839661
HPP-22 Replacement Leads link - great pic of the pinout.
Tip > Positive
Center > Signal
Shield > Negative/Ground
Cheers guys!
Help! Plugs and wiring clarification. Nemesu Beginner Training Area (Aircraft-Electric) 18 Oct 22, 2016 01:38 PM
Discussion Should I get a Hitec hpp-22 for my radio Torchwork Radios 3 May 12, 2015 02:48 PM
Discussion Hpp-22 skyrock Hitec/Multiplex USA 2 Nov 29, 2009 07:00 AM
Discussion Availability of the HPP-22 mcsarge Hitec/Multiplex USA 4 Oct 02, 2009 11:29 AM
Discussion What is HPP-22? gkamysz Hitec/Multiplex USA 1 Jun 30, 2009 11:48 AM
