Aug 19, 2018, 05:18 PM
Originally Posted by NL_Hees
No, that will set the throttle value at which you FC will allow you to arm the copter. (This should therefore always be above them minimum value your throttle stick can go)
You need to increase the “Motor Idle Throttle Value (percent)” on the config tab. I have mine set to 8 now and haven’t had any tumbles out of the sky since then.
Hi,
have you experienced any FOD since you applied this value?
Nov 10, 2018, 12:25 PM
iksobarg's Avatar
Hellooo, "ah geez" I ordered this rchalance (?) 35a aio esc that's 8pin. How, if possible do I make it work with the 6pin input of the stock x220s fc?
Nov 12, 2018, 07:25 AM
Check the wiring diagram of both and only connect what you need. So leave 2 cables out and connect them to the 6 pin you already have.
Nov 13, 2018, 10:47 AM
iksobarg's Avatar
Looking for the relevant schematics. Wish me good luck.
John
Sep 18, 2019, 10:28 AM
Eachine Wizard X220S / Hero 4 (5 min 43 sec)
Sep 23, 2019, 12:58 PM
Hi!
I've recently bought an Eachine Wizard X220S, my first serious FPV drone... what a beast!
But i have a problem with the OSD of my Eachine VR 006 glasses (recycled from a RTF Eachine 013 kit); i want to see the battery voltage on my OSD, but when i set on Betaflight the battery info and saving the settings, when i turn on my glasses, i don't see it.
Why? It's because Eachine VR 006 are cheap glasses and i cannot change the OSD options? What am i doing wrong?
Sep 23, 2019, 05:22 PM
Originally Posted by Azgana
Hi!
Are you seeing it on the Betaflight OSD tab? If so, it may be off the edge of your goggle screen (it's a PAL / NTSC thing). Try moving it toward the middle on OSD screen and see if you can see it. Make sure to hit save between moves.
Sep 24, 2019, 10:11 AM
Yep! I moved the icons more next to the centre and now i see them! But i don't know why the voltage battery icon indicates 0.00 V even if the battery is charged
Resolved! The VBAT option on Betaflight was not enabled.... noobie error, i'm just at the beginning! Thanks!
New Product Eachine Chaser88 F3 FPV Racer ARF with 4 In 1 6A ESC 5.8G 40CH VTX 800TVL 1/3 Cmos victor_aem Micro Multirotor Drones 44 Nov 27, 2017 12:11 AM
New Product Eachine DVR03 DVR AIO 5.8G 72CH 0/25mW/50mW/200mW Switchable VTX 520TVL 1/4 Cmos FPV kremerFPV FPV Equipment 21 Jul 22, 2017 03:19 AM
