Bat-100 Micro Drone - 100mm BRUSHLESS FPV quadcopter - $96 - RC Groups
May 20, 2017, 08:57 AM
Originalas's Avatar
New Product
Just come up on a new 100mm brushless quadcopter Bat-100 Micro Drone!
I still enjoy my Eachine QX95 and Bat100 is pretty much the same size, weight yet BRUSHLESS!
Another nice feature integrated OSD with the Betaflight F3.
Bat-100 Micro Drone Specification:
Item name: Bat-100 mini FPV racing drone
Wheelbase: 100mm
Size: 95mm * 80mm * 25mm
Weight: about 30g (without battery)
Motor: 0705 15000KV brushless motor
ESC: 6A BLHELI_S 16.5 2-3S 4in1 ESC Dshot600
Propeller: 56mm 2-blade propeller
Camera: 600TVL camera with 25MW 48CH NTSC/PAL vedio transmitter
Flight controller: Minicube Betaflight F3 6DOF built-in OSD
OSD: Betaflight OSD
Firmware of FC: Betaflight 3.1
Flight time: 4-6 mins
Buzzer: 3*13mm (with LED)
Battery: 3.7V 500mah 30C lipo battery
May 20, 2017, 09:00 AM
Fan of just about anything RC
SoloProFan's Avatar
Frame looks a bit thin, with those narrow arms. But we'll just have to wait and see how strong it is.
May 20, 2017, 09:11 AM
there is already thread about this:
https://www.rcgroups.com/forums/show...5MW-48CH-600TV
May 21, 2017, 02:15 AM
Originalas's Avatar
Should be more than enough for a 50g model.
QX95 is 40g and it works perfectly with even thinner hollow arms.
We will find out soon. It should be in stock early next month.
May 21, 2017, 05:14 AM
SoloProFan's Avatar
Quite a few people broke the frame on the QX95. Also, hopefully the 0703 motors will offer more power than their brushed counter parts, otherwise this one will fly more docile than the brushed FPV quads of similar size, since it's heavier, but still uses the same props.
May 21, 2017, 06:22 AM
Flight for life
geotric's Avatar
Maybe but my QX95 frame is quite solid. More than I imagined . I guess it is all in the way you fly and crash. I try to crash with class. Like Casey does.
May 21, 2017, 07:29 AM
Originalas's Avatar
Every quad can be broken with enough determination though I wouldn't complain about QX95 build at all.
Motors should be around 35g pull per motor, 140g total.
May 25, 2017, 12:34 PM
Originalas's Avatar
New video. And it's actually even lighter than the QX95.
Bat-100 1S brushless fpv drone (1 min 55 sec)
Jul 18, 2017, 12:05 PM
Originalas's Avatar
Finally in stock, ordered mine!
Jul 18, 2017, 10:08 PM
Taiaumun's Avatar
Got mine last week, my first 1s brushless quad and seems quite good. Paired with the GN 450 80c battery, the punch surprised me and handles well too. Not in wind though, it's too light and gets blown around. Not crashed it severely yet so can't say about the frame toughness. However I had a motor fail out of blue so had to order a new motor!
Jul 20, 2017, 01:47 AM
BG addict.....
Fleetwood1973's Avatar
I got mine coming too, couldnt resist the compatibility with all the QX/EX 1S batteries I have. Concerned about those motors failing though.... seems on par with EVERY 1S brushed quad I have bought from BG.... stock motors seem to be junk and fail. Maybe I should just go ahead and order some replacement racestars https://www.banggood.com/Racerstar-R...l?rmmds=search.
How is the OSD? Thats the real reason I got it....
Fleet
Jul 20, 2017, 09:36 AM
Taiaumun's Avatar
Fleet
OSD seems fine but I only got two flights with it before motor #1 failed, got a couple of spares coming. If they are as fragile as you say, this could be the only 1s brushless I'll get for the time being.
Which kv racerstar would you recommend?
Jul 20, 2017, 03:20 PM
Fan of pusher multirotors
Tachikoma's Avatar
Are we sure it's the motors failing and not the ESCs? Seems odd it'd be the motors - on brushless setups those usually only die to overwhelming physical force, and the ESCs are the part that releases the magic smoke.
Jul 21, 2017, 01:50 AM
Taiaumun's Avatar
Yes on this occasion I am certain as the motor is stuck and doesn't spin the same as the others, physically there is a mechanical issue
Jul 21, 2017, 12:50 PM
BG addict.....
Maybe you misunderstood me.... I am not sure if the motors ARE fragile, but the brushed ones (this is my first brushless from BG) have mostly left me needing to replace the entire set with racestar reds.
I would get the 15000kv (all 4) to match what it came with, or 12000kv if you have experience and know these will be ok. Good luck.... im am considering buying the Realac 130mm frame and some 1306's to build a 2s/3s bird for inside.
Fleet
New Product Bat-100 Micro brushless FPV Racing Drone smg24 Micro Multirotor Drones 9 Aug 27, 2017 02:40 PM
New Product Bat-100 100mm Mini FPV Racing Drone PNP with F3 10A BLHELI_S Dshot600 25MW 48CH 600TV smg24 Banggood.com 5 Aug 27, 2017 02:40 PM
New Product Eachine Aurora 100 100mm Mini Brushless FPV Racer BNF w/ F3 OSD 10A Dshot600 [$130] D Gains Micro Multirotor Drones 12 Mar 13, 2017 11:50 AM
New Product Smart 100 100mm DSM2 PNP Micro FPV Quad fastmax Micro Multirotor Drones 11 Mar 05, 2017 03:51 PM
New Product Micro Mini Multirotor FPV Quadcopter Racing Drone Mosquito 100 Class RC Kit AEOTech Micro Multirotor Drones 0 Dec 15, 2016 09:53 PM
