This thread is privately moderated by old4570, who may elect to delete unwanted replies.
May 19, 2017, 11:13 PM
old4570's Avatar
openTX Firmware ( Turnigy 9XR pro )
Playing with the iRangeX IRX4 multi protocol module meant installing openTX 2.2 firmware to my 9XR pro ..
"AND" I have to honestly say , openTX 2.2 Bites hard ..
Seriously , can you trust this open source firmware = No you can't ( so is my opinion ) ...
I have found several issues , and one issue makes the firmware some what NQR ( not quite right )
I post this as moments ago openTX crashed and burned , wiping all settings etc .
A) Installing openTX AETR does not mean you get AETR because for me Aileron and rudder were switched ..
So I got RETA , even though the firmware was installed AETR ( ????????? )
Now you assign function to channels , but this then leaves the trim tabs as they were , so if you need to trim on the fly it could be problematic ...
Possible solution is to install the firmware RETA , so if Rudder and Aileron revers it will then be AETR ..
B) After re flashing openTX after it crashed , it began to freeze on start up .. Removing the SD card seems to be the cure , so also looks like some sort of SD card issue as well ...
So what does this mean ?
It simply means that openTX is not entirely stable , and if its not stable , then how safe is it to use ?
Discussion Update XJT firmware using OpenTX + 9XR Pro??? SKT FrSky 0 Oct 10, 2016 12:35 AM
Help! Turnigy 9xr pro lcd issue and general firmware issue Kilomanjaro4 Beginner Multirotor Drones 2 Oct 01, 2016 10:57 PM
Discussion FrSky XJT TX Firmware Flashing Using The Turnigy 9XR Pro Pyr8 Radios 0 May 20, 2016 03:12 AM
Discussion Turnigy 9XR Pro OpenTX not transmitting? X4R SB + XJT simonsez Radios 0 Apr 24, 2016 11:11 AM
Question Blade 300X with Turnigy 9XR (OpenTX) DutchRC Electric Heli Talk 9 Sep 23, 2014 08:50 PM
