This thread is privately moderated by glassfox, who may elect to delete unwanted replies.
May 19, 2017, 09:23 PM
glassfox's Avatar
3010 High Thrust Propeller on Big drones From Foxtech
Get this most thrust propeller here: https://www.foxtechfpv.com/supreme-c...ler-3010t.html
3010 High Thrust Propeller on Big drones (5 min 53 sec)
Foxtech Supreme C/F Propeller 3010T
Foxtech Supreme CF 3010T propeller are specifically designed for heavy duty multicotpers. Well balanced, polished and reinforced, Supreme carbon fiber propellers guarantee very little deformation even with very high load and give you a safe and quiet fly.Foxtech Supreme CF 3010T propeller is available for XRotor 8120 100kv motor and T-motor U12/U13 motor etc.
The Supreme 3010T Prop with higher strength, lower vibration and better antitorque. With its core filled with light but strong compound materials, this new arrival is very light, only 115g. Its excellent air dynamic design makes great improved efficiency.
Specifications:
Material: carbon fiber
Light weight compound core
1x10mm hole in the center
4x3mm hole around the center hole
Length:30 inch
Pitch:10.0 inch
Each weight:115g
Data Propeller shootout for 8,5x20mm brushed motors (Thrust Tests on Racerstar 8520) muteFPV Micro Multirotor Drones 25 Mar 05, 2017 07:10 AM
Discussion Police called, neighborhood on high alert after drone sighting destey Model Aircraft & Drone Advocacy 19 Apr 19, 2016 11:05 AM
New Product BLPS 100 micro gear box- micro motors drive big size propellers producing high thrust AEORC Electric Plane Talk 4 Apr 12, 2016 03:03 PM
Discussion Estimating static & dynamic thrust from motor/propeller characteristics Jon Kuriloff Power Systems 17 Nov 28, 2014 11:29 AM
