This thread is privately moderated by Cesco, who may elect to delete unwanted replies.
May 19, 2017, 02:38 PM
Cesco's Avatar
Blueseries simonk uart firmware
This firmware uses the serial connection from FC to ESC. It uses the original konze uart protocol at 38400 baud.
Protocol is:
- syncbyte 0xF5
- one byte throttle value for esc 1 range 0 to 200.
- one byte throttle value for exery other esc
Example message for 2 motors, zero throttle: 0xF5,0x00,0x00
Example message for 4 motors, mid throttle: 0xF5,0x64,0x64,0x64,0x64
The firmware is bs_nfet type, tested with hk blue series 20A and hk 20A ubec.
It should work with every bs-nfet esc where int0 is connected to rxd.
Yes, i have flown this. Old dji F450 frame, blue-series esc, multiwii FC. See attached picture. All pwm pins empty.
I can provide output driver for avr multiwii or stm32 baseflight.
Attached Simonk/konze uart firmware bs-nfet with icp and int0 disabled, bootloader enabled, uart enabled.
Comes with 4 different motor ID's.
When programming with built-in bootloader you need the "bs_nfet_uart_noboot" version.
If you want source ask me, i provide.
Attached processing test program for mot1 and mot2 named rcsim.
May 23, 2017, 11:44 AM
Cesco's Avatar
The BLHeli afro avrstudio4 project, working uart konze protocol, 62500 baudrate.
Discussion Firmware help - RB100A (rb70a simonk firmware) iscle High Performance 18 Aug 15, 2020 09:23 AM
Help! SimonK with Blueseries and rctiger MT3515 motor HuguesD Multirotor Drone Power Systems 1 Oct 22, 2013 10:41 PM
Question Blueseries 40A flashed with SimonK ? HuguesD Multirotor Drone Power Systems 3 Oct 18, 2013 02:02 AM
Help! SimonK, Blueseries 40A, Comp_pwn, finding optimum dead_time value? Mr_westie Multirotor Drone Electronics 2 Jun 03, 2013 01:14 AM
Discussion HK blueseries 8Khz or F-30A 8/16Khz - Simonk FW alfapistola Multirotor Drone Talk 6 Jun 11, 2012 11:26 AM
