Help me with what to buy! - RC Groups
May 19, 2017, 02:05 PM
Help!
I am planning to build a small-medium plane made out of foam that apparently is easy to make but I have never done anything like this before. I have searched around a bit on HobbyKing to find the electric parts for a scratch build and there is a picture of the wishlist in this post. I added two different motors since I wasn't sure which I should use. Please tell me what you think and what parts I should replace, any help is appreciated!
May 19, 2017, 02:58 PM
Hot glue held together by foam
balsa or carbon's Avatar
Where in the world do you live ? USA , Europe , Australia ?
Have you flown an RC plane before ?
If not , will you have the assistance of an experienced RC flyer ?
How big is your flying area ?
May 19, 2017, 03:32 PM
Drone offender FA377YHFNC
You don't say anything about what plane you're going to fly. So realize that some advice can't be too specific.
On the radio you've specified a Mode 1 radio. Different parts of the world fly different modes. If you aren't rock solid about doing what everyone else does, you'll find yourself in a position where if you want flying help, nobody but you will be able to fly the plane. Don't make a mistake on what mode you buy.
You apparently are looking to fly on less than 20 W of power but have a big heavy 2600mAh battery. You'd be much better served going with 1000mAh to 1300mAh battery. If you really find you WANT 2600mAh just hook two 1300s together in parallel.
I've had great luck buying HK's Plush ESCs. I don't know about the one you ordered. Make sure that the motor you eventually use will swing the prop you bought at a suitable RPM and draw a certain number of amps. Then buy your speed controller with the ability to handle 1/3 more amps than you'll need. Guessing on motor/prop/ESC combinations makes for some flamy stuff coming out of various components.
The HK15178 servos are awesome. I've used them five years in my Slow Stick without a glitch.
May 20, 2017, 01:34 AM
Wake up, feel pulse, be happy!
Piece's Avatar
The battery you picked is designed to go in a transmitter (the remote/handset/box with sticks/whatever). It's​ rated for less than 3A continuous output and will be useless for powering a model.
At risk of wasting my time typing, I'll wait to see what model you intend to build before advising further.
May 20, 2017, 04:25 AM
If all we know about the plane is that it is "small-medium" then all we can advise about the components is they should probably be small-medium too.
More details would help.
Steve
May 20, 2017, 08:21 AM
Perpetual Noob
BoxCar31's Avatar
www.flitetest.com
May 20, 2017, 09:49 AM
Sorry everyone for the lack of information.
Yes I have flown an RC plane before, but it was a while ago.
My neighbor has flown alot of RC planes and I would probably get some help from him if I need to.
My flying area is very big, since I live on an old farm where we have lots of space
May 20, 2017, 09:57 AM
Steve
I am basically planning to build something like Samm Sheperd's "$5 Trainer":
$5 Trainer Build Techniques (7 min 53 sec)
$5 RC Trainer (5 min 25 sec)
Since I have never done this before, I don't really know what you need to know other than that. Do you need to know the mass of the plane? Because I have no idea.
If someone can provide a really basic list of parts that I could buy, that would be awesome! It doesn't have to be expensive or anything.
Building a small sled, like Samm did, would be a great way of figuring out how the electronics work before I try to build a plane
May 20, 2017, 11:09 AM
OK , cool !
Usually plans for RC planes include electronics recommendations ; if the plans for the plane you want to build don't include electronics recommendations , post a link to the plane or a detailed description so we can help you . Which electronics to get depends on the weight of the plane , and the type of performance that is expected from it ...... slow flying trainer , 3D plane , fast jet , motor glider , etc .
May 20, 2017, 11:41 AM
OK , cool !
I am basically planning to build a plane like Samm Sheperd's "5$ Trainer":
I can't find any form of insulation foam that he used in his video(s), can you suggest other building materials? Will cardboard work or is it too weak?
May 20, 2017, 01:27 PM
OK , cool !
Translation: always start with the plane and back into the components. It's a waste of time to do it backwards.
We resume our normal garbled English.....
May 21, 2017, 08:02 PM
https://www.youtube.com/watch?v=LKt6bt6I1Is
https://www.youtube.com/watch?v=aV5hILJe20U
Do you want to build a 3 channel high wing trainer ( like in video #1 ) or a 4 channel low wing plane ( like in video #2 ) ?
I watch Samm's videos and subscribed to his YouTube channel a long time ago ; but for your first time building a plane , I recommend building a simpler , well supported plane . A well supported plane will have a thread with downloadable plans , electronics recommendations , and plenty of support from the designer and others who have built the plane .
There are MANY threads for scratch built trainers in the " Foamies ( Scratchbuilt ) " forum :
https://www.rcgroups.com/foamies-scratchbuilt-428/
My favorite 3 channel trainer is the EzFly , it's what I've used to teach dozens of people to fly over the last 7 years . Here is the thread for the EzFly :
https://www.rcgroups.com/forums/show...-trainer-plane
Let me know if you want to build one , I can help you through the whole process . The best plans for the EzFly are these ( PDF file ) :
https://www.rcgroups.com/forums/show...6&d=1334660760
Look for foam sheets in hardware/building supply stores , or art supply stores , or office supply stores . You can also get foam sheets from HobbyKing :
https://hobbyking.com/en_us/aero-mod...___store=en_us
Click on EU warehouse at the top .
Cardboard can work for building planes , but it's not ideal .
Here is one of my EzFlys :
Copy of EzFly with under-cambered wing (1 min 57 sec)
May 23, 2017, 01:56 PM
Thank you for the help! I don't know why, but I get the feeling that I only want to build one of Samm's planes. But if I decide to follow the EzFly build and order whatever electric components needed, will those be enough for bigger and more different future planes? I am on a very limited budget, so any reusable parts will be worth alot to me.
May 23, 2017, 03:16 PM
OK , Samm lists electronics and other info underneath his videos . I noticed that in the video info , he said his plane flew poorly , and needed a lot of tweaking before it would fly well .
One good indicator for deciding which plane to build : is to research how many people have actually built the plane ..... and find out how it turned out for them . I don't know how many people have built Samm's plane , but I do know probably hundreds of people have built the EzFly - the EzFly thread has 2,370 posts as of now .
Any electronics you get for a plane , can be used over and over again on different airframes where the weight and type of flying ( slow trainer , fast park jet , hovering 3D , etc ) are about the same .
One advantage of the EzFly is that it's a pusher , so if you crash nose first ( and damage the foam airframe beyond repair ) the motor/prop likely won't be damaged , and can then be transferred to a new airframe .
May 23, 2017, 11:07 PM
ozmo01's Avatar
2ND Flitetest.com free plans FREE is Good (-:
Discussion please help me decide on which first Quadopter to buy carkev Beginner Multirotor Drones 11 Nov 11, 2016 04:20 PM
Discussion Tell me what Racer to buy. wopachop FPV Racing 14 Oct 11, 2016 05:38 PM
Help! Help me buy my first FPV gear! rich95 FPV Equipment 2 Oct 07, 2016 04:37 AM
Question Mind helping me with this buy list? New to FPV Etnos FPV Talk 0 Jul 30, 2016 05:58 PM
Discussion Help me choose/buy a gimbal runzwithsizorz FPV Equipment 0 Oct 09, 2015 10:04 AM
