Truckload of gliders. - RC Groups
This thread is privately moderated by kclements, who may elect to delete unwanted replies.
May 19, 2017, 12:31 PM
Trader Rating: 47
For Sale
Just picked up a truckload of gliders. All of them new in the box.
Located in Kirkland Washington.
They are all FlyFly Hobby
None of them include electronics. If it says "electric" in the description then the kit is the version that can use a motor.
Most of the "electric" kits come with prop hub, prop and spinner.
Here is the list. The number in front is the current quantity I have available.
(ALL SOLD OUT ) Freebird FF07 electric $80obo
The Free Bird designed for beginner to middle level pilot. It is the perfect aileron glider / electric airplane for slope or glass flying field.
This version is ready to acept your choice of electric motor & ESC.
The Free Bird equipped with the cross tail surface for fast aileron roll.
A slope soarer created with performance aerobatics firmly in mind. Those sleek purposeful lines combined with a computer enhanced MH32 wing section provide both speed and efficiency. And the GRP molded fuselage and tough balsa/ply wings give the durability needed for the harsh environment of most slope soaring sites! Not a model for the beginner, but this superb glider will enthuse and delight competent pilots!
SPECIFICATION:
Control's - Ailerons, Elevator, Motor
Material: Fibreglass Fuselage, Balsa Wings
Build Type:ARTF
Wing Area: 19dm sq.
Airfoil: MH32
Length:835mm
Wingspan: 1450mm
Weight: 590g
Servos:3 x 9g
Skill:Intermediate
Power system : (Not included)
Motor : 1800KV (inrunner)
ESC: 40A
Battery: Li-Po, 7.4v, 1300mAh (Required),
propeller: 7 x 4 folding propeller
(4) Trendy FF-BO24 electric $120 each obo
SPECIFICATION
Material: Fibreglass Fuselage, Built up wings
Wing Area:31.7 dm sq.
Weight: 800g
Length: 1000mm
Wingspan: 2250mm
Servo's: 5 x Micro (Required)
Motor: B28 1800KV inrunner (Required)
Folding Propeller: 7 x 4 (required)
ESC: 40A (Required)
Battery: 11.1V 1300ma Lipo (Required)
(2) Deity FF-B020 Electric $75obo
Power System (Not Included)
Motor: 1800kv (inrunner)
ESC: 40A w/BEC
Propeller: 10 x 6 Folding Propeller
Spinner: 30mm,shaft:4.0
Battery: Li-Po, 11.1V,1600mAh
SPECIFICATION
Length: 1060mm
Weight: 800g
Wingspan: 2000mm
(3) Geronimo 2.6m FF-B026 Electric $140 each obo
SPECIFICATION
Material: Fiberglass Fuselage, Balsa Wings
LiPo:14.8v 2200mAh 20C (Required)
Electric Motor:720kv (Outrunner) (Required)
Propeller: 11 x 7 Folding Propeller (Required)
ESC:40A w/BEC (Required)
Servo's: 4 x Micro, 2 x Mini (Required)
Wing Area: 50dm sq
Airfoil: HN354(Mod)
Wingspan: 2.6M
Length:1230mm
(3) Geronimo 2.0m FF-B025 Electric $120 each obo
SPECIFICATION
LiPo: 11.1v 1800-2200mAh 20C (Required)
Electric Motor: B28 1800kv (Inrunner) (Required)
Recommended prop/motor setup FF18-01
Wing Area: 34dm sq
Airfoil: HN354(Mod)
Wingspan: 2.0M
Length:1160mm
(ALL SOLD OUT) DG-1000 FF-B001 Electric $100 each obo
This stunning 2.6 meter span DG-1000 glider has been optimized for use with your choice of electric motor, ESC and battery. This beautifully crafted ARTF model features a precision molded fiberglass fuselage pre-painted to a high gloss finish. The flying surfaces are fully built up and sheeted for optimum strength. (Required 4S 2200ma Lipo)
Control's - Ailerons, Elevator, Rudder, Motor
SPECIFICATION
Radio: 4 Ch.
Servos: 3 Micro , 1 Standard (Required)
Weight: 1100g
Wingspan: 2630mm
Build Type: ARTF
Length: 1130mm
Skill: Intermediate
(3) ASW-28 FF-B008 $80 Each obo
This ASW-28 scale ARTF model includes a high quality molded fiberglass fuselage and factory built wooden wings. The model is highly prefabricated and only requires minimum time to assemble and is straightforward to fly. Supplied complete with instructions and a comprehensive hardware pack.
Control's - Rudder, Elevator, Ailerons (Servo's Required)
SPECIFICATION
Radio: 3 Ch.
Weight: 1400g
Wingspan: 2530mm
Build Type: ARTF
Length: 1170mm
Skill: Intermediate
(2) ASW-28 FF-B008E Electric $120 Each obo
SPECIFICATION
Radio: 4 Ch.
Weight: 1100g
Wingspan: 2630mm
Build Type: ARTF
Length: 1130mm
Skill: Intermediate
(ALL SOLD OUT ) Geronimo 3M FF-B027 $150 each obo
SPECIFICATION
LiPo:18.5v 3200mAh (Required)
Electric Motor:1200kv (Outrunner) (Required)
Wing Area: 60dm sq
Airfoil: HN354(Mod)
Wingspan: 3.0M
Length:1270mm
(ALL SOLD OUT ) DG-808S 4M Competition NON/Electric Glider only FF-B015 $200 each obo
The DG808S is FlyFly's largest ever scale glider with a massive wingspan of 4m! A beautiful model that really captures the lines and grace of the fullsize. Not only that, the HQ2512 wing section gives the kind of efficient flight performance that you would expect and those sexy wing tips add great low speed stability as well as reduced drag.
SPECIFICATION
Wing Area: 55.80 dm sq.
Airfoil: HQ2512
Landing Wheel Factory installed
Servos Required: 5x Micro, 1 Standard (Aileron,Flap,Elevator,Rudder)
Weight: 3500g
Length: 1560mm
Wingspan :4000mm
(12) Condor Magic EVO 4 3M Electric FF-B014 $150 each obo
The Condor Magic Evo4 not only has the looks to impress, but backs up those graceful lines with stunning levels of performance. Featuring a super-efficient Eppler 205 wing section, this quality ARTF has a factory painted fiberglass fuselage and traditionally built fully sheeted wings, hand finished in a tough glossy film.
SPECIFICATION
Material: Fiberglass Fuselage,Balsa wings
Wing Area: 50.40dm sq
Airfoil: Eppler 205
LiPo Required: 4S 14.8v 2200mAh
Electric Motor Required : 400-500W
Speed controller required: 40A
Servo's Required - 5 x Micro, 1 x Standard (Aileron,Flaps,Elevator,Rudder)
Length: 1270mm
Weight: 1700-1900g
Wingspan: 3000mm
May 19, 2017, 05:16 PM
Trader Rating: 11
I will PM you. I'd like the
and the
May 19, 2017, 05:47 PM
Trader Rating: 17
Puerto Rico (USA)
luis94's Avatar
Will you ship???
May 19, 2017, 06:13 PM
Trader Rating: 10
I will take a diety. pm sent
May 19, 2017, 06:37 PM
Trader Rating: 2
MrMPX's Avatar
Condor Magic shipped to SO Cal?
May 19, 2017, 07:05 PM
Trader Rating: 47
I will ship with FEDEX or UPS only.
Please PM me with your zipcode and what gliders you would like and I will get a shipping quote.
May 20, 2017, 05:32 PM
Trader Rating: 1
P.m. sent for Geronimo to meter
May 25, 2017, 05:57 AM
Trader Rating: 0
the noob one
Hi I would like to buy a
Miami Fl, 33141
Need a quote thanks.
For Sale TRUCKLOAD of Gliders in the Seattle area. kclements Aircraft - Sailplanes (FS/W) 47 Aug 20, 2017 11:37 AM
Discussion original ULF1 Glider as registered RC-Glider uwe neesen Scale Sailplanes 9 Sep 25, 2016 08:35 PM
For Sale Anyone interested in a truckload of helicopters"NO LONGER FOR SALE" 72501 Aircraft - Fuel - Helis (FS/W) 3 Sep 22, 2016 09:21 PM
Help! anyonehave a smaller handtoss glider, or powered glider? epoweredrc Atlanta Area RC 4 Aug 11, 2016 08:25 PM
Wanted used R/C items 1 piece or truckload shahoo80 Cars - Cars and Parts (FS/W) 1 Oct 31, 2004 10:30 PM
