Bl Heli and Aircraft - RC Groups
May 19, 2017, 12:11 AM
Question
I was setting up quadcopters and most of my electronics are for that.
I went back to finishing an airplane I was building.
The question is if there is a problem with using BlHeli speed controllers with an airplane instead of a quadcopter. It sure seems to me that it wouldn't make a difference. Any advice from more experienced people would be greatly appreciated.
Tilo
May 19, 2017, 03:22 AM
Wake up, feel pulse, be happy!
Piece's Avatar
BLHeli is very superior to the factory firmware you'll find in most fixed-wing ESCs. Proceed with happiness.
Latest blog entry: My feet smell funny
May 19, 2017, 07:57 AM
I'm not sure if this is true of BLHeli ESCs, but many ESCs for multi-rotors are designed with fast response as a priority, and as a result (and also perhaps to keep the package small?) might not have some of the features that you might want in a fixed-wing aircraft or heli, such as motor braking and/or soft start.
But if you don't want any such features, there's no reason not to use them in fixed-wing models.
May 19, 2017, 08:21 AM
JohnFM's Avatar
BL Heli ESCs are fully programmable for fixed wing, helicopters, or multi rotors.
May 19, 2017, 08:32 AM
yank and bank!!
I'm using a Blheli equipped esc in a plane and love it. the esc is light for it's rating (even with the separate bec) and has reportedly has just about the highest switching spec of any esc commonly available. On top of all that, the esc costs about 40% of what "airplane esc's" cost for the same amps.
I'm obviously not using the closed loop features and I don't use the brake.
May 19, 2017, 09:34 AM
JohnFM's Avatar
If there's a problem with BL Heli ESC's it's that they're still not made larger than 30 Amp.
May 19, 2017, 09:59 AM
yank and bank!!
Yep, it would be nice if they made blheli equipped esc's with at least 75A sustained capacity.
May 19, 2017, 10:03 AM
JohnFM's Avatar
Even 50A would be nice
May 20, 2017, 01:53 PM
That's what my logic was saying, I just wanted wiser/more experienced advice. Thank you everyone. I think I will "Proceed with happiness"!
Tilo
May 29, 2017, 02:59 PM
Only issue I've had is with throttle stick programming. It got kind of funky and I'm not sure why. I managed to recover. Maybe owning a dedicated programmer would help to reset the ESC.
Oct 07, 2017, 01:34 PM
BLheli has no option for dynamic braking so at zero throttle, propeller will spin!
A plane is slowed by freely spinning propeller (with no activated brake) it also increases probability of interacting of propeller with the ground during landing.
Brake off is not ideal settings for a plane.
Nov 05, 2017, 03:25 AM
Hi, any chance of some settings please, perhaps a screen shot, i managed to get 6 plush 40a esc's off of a chap via ebay recently and they all have blheli on them.
I wish to use them on a plane, I have blheli software and managed to connect laptop to the esc, but not 100% sure on settings.
one issue i get seems to be the throttle is quite slow from 0%-100%
Many thanks.
(just using 1 esc in each plane, lots of settings, not sure what does what)
thanks
Feb 24, 2018, 06:40 AM
Completely incorrect.
Active freewheeling/damped light plus break on stop.
At least do some basic research before saying something doesn't work at all.
Feb 24, 2018, 08:59 AM
yank and bank!!
You brought a three month old thread back to the forefront so you could talk smack to someone who posted in it?
Apr 08, 2018, 03:29 PM
I had BLheli (16.2. something) on my blue 60A ESC approx. 1.5 year ago.
Also found this thread(s).
https://github.com/bitdump/BLHeli/issues/127
custom FVT20A fw for a fixed wing (active breaking support)
https://github.com/tcalvert/BLHeli/t...sions/TCALVERT
I don't currently have BLheli on any of my ESC (to test it), but can you confirm, that with settings above ESC actively breaks (with 0 throttle, ESC has to force the motor actively break against propeller (spinning by moving air))?
As far as I remember with your suggested settings, ESC only actively forced motor to stop almost immediately and then (with 0 throttle, during gliding) it was freewheeling...,
That is not active breaking (needed for a fixed wing).
Can you confirm, that with above settings active breaking is now working correctly?
Help! Emax BL Heli problems whiteycub Power Systems 2 Apr 22, 2018 03:38 PM
Discussion BL Heli issues Mike Abel Beginner Multirotor Drones 2 Nov 10, 2016 10:18 AM
Discussion In your opinion what is your favorite 30amp escs running bl heli s Jasondg420 FPV Talk 0 Sep 28, 2016 04:40 AM
Discussion Bl heli s esc for 5 or 6s? Redtail2426 Multirotor Drone Electronics 1 Aug 22, 2016 07:31 PM
Discussion Bl heli updating with a mac? UltraRC Multirotor Drone Talk 4 Oct 06, 2015 07:26 PM
