GPS not connected message - RC Groups
May 18, 2017, 07:54 PM
Help!
Recently bought the vector system from someone but I'm having problems with the GPS. It will only say "GPS not connected!" in the display. Same result on either bus connector, all connections good (and plugged into the correct socket on the vector unit), latest firmware. System will recognise if the module is not plugged in at all. At no point do I see an led light up on the gps module. The compass/magnetometer works fine and will calibrate as well. Disconnected everything and also did a factory reset. Seems everything works fine except for the GPS not connected message.
So, did I get screwed and bought a busted unit from someone? Any recourse other than dropping another $60 for a new GPS module?
Thanks in advance.
May 19, 2017, 04:19 AM
because rust never sleeps....
HugoRogers's Avatar
You dont say where you are, but one option is to get EagleTree to test it. This is only a viable option for those living in the US though as far as I can tell.
May 19, 2017, 06:44 AM
HugoRogers's Avatar
Having checked the tarriff, the price for repair of this unit is $50 (assuming it is not under warranty). You need to add the cost of tracked postal service both there and back too.
The other complicating factor is that the unit might be OK, there could be a fault in the bus cable or even in the Vector.
Best thing to do is to find someone else with Vector kit and see what happens when you plug someone else's GPS unit into your Vector.
May 19, 2017, 10:18 AM
I'm in Texas in the US. Price for repair is $50? Might as well just buy a new unit from them for $56 then.
May 19, 2017, 11:09 AM
HugoRogers's Avatar
Assuming it is the unit that is faulty, yeah, it's the only sensible option.
New Product tBeacon: UHF beacon with GPS connection, VOICE messaging and REMOTE activation out0f0rder FPV Equipment 63 Sep 08, 2017 08:00 PM
Help! Eagle Tree Vector GPS/Mag not connected? nehlewolf Multirotor Drone Electronics 1 Jan 31, 2017 06:24 PM
Mini-HowTo How to avoid the "Not connected" message when starting the Phantom 3 chopperaddict Beginner Multirotor Drones 0 Apr 11, 2016 09:44 AM
Discussion GPS board not detected when GPS module is connected IconFlyer Aerial Photography 17 Feb 15, 2012 05:20 AM
