May 16, 2017, 10:08 PM
MATEKSYS Flight Controller F405, 32K Gyro, BFOSD, 5xUARTs, SD Slot
  • MCU: 168MHz STM32F405
  • IMU: 32K ICM20602 accelerometer/gyro (SPI)
  • Support 32K Gyro update & 16K PID Loop
  • OSD: BetaFlight OSD w/ AT7456E chip
  • Blackbox: MicroSD card slot (SD/SDHC)
  • VCP, UART1, UART2, UART3, UART4, UART5
  • Built in inverter for SBUS input (UART2-RX)
  • PPM/UART Shared: UART2-RX
  • Support SoftSerial on S5 & S6
  • Battery Voltage Sensor: 1:10
  • Currsnt Sensor: No (FCHUB-6S option)
  • BEC 5V & 10V: No (FCHUB-6S option)
  • LDO 3.3V: Max.300mA for Spektrum RX
  • WS2812 Led Strip : Yes
  • Beeper : Yes
  • RSSI: Yes
  • 2x LEDs for FC STATUS (Blue, Red)
  • 6x PWM / DShot outputs without conflict
  • 5x UARTs
  • 1x Group of G/S1/S2/S3/S4 pads for 4in1 ESC Sginal/GND
  • 4x pairs of corner pads for ESC Signal/GND connections (DSHOT compatible)
  • 1x Side-press button for BOOT(DFU) mode
  • 1x 16pin bottom mounted FFC Slot for FCHUB-6S connection
  • 36x36mm PCB with 30.5mm mounting holes
  • w/ 1x 0.5mm*16Pin 5cm Flexible Flat Cable
  • w/ 4pcs M3 Anti-vibration Standoffs
Details: http://www.mateksys.com/?portfolio=f405-osd
F405-AIO w/PDB,Dual BEC,Curr Sensnor
  • Input: 9~27V (3~6S LiPo) w/TVS protection
  • PDB: 4x30A (Max.4x50A), 6 layers*2oz copper PCB
  • Dual BEC: 5V 2A & 9V 2A
  • Current Sensor 200A (Scale 165)
Details: http://www.mateksys.com/?portfolio=f405-aio
Firmware based on OpenSource BetaFlight
MatekF405 Target https://github.com/betaflight/betafl...rget/MATEKF405
BetaFlight Wiki https://github.com/betaflight/betaflight/wiki/matekf405
Facebook Group: https://www.facebook.com/groups/1882519175321708/
May 17, 2017, 02:01 AM
Jimster71's Avatar
It looks a good combination with this and the PDB. Have you done anything to increase the durability of the ribbon connector? They are normally a point of weakness.
May 17, 2017, 03:40 AM
Major online stores that sell or plan on selling this FC:
China Based:
Banggood (lowest price)
Helipal
US Based:
PiroFlipRc
RaceDayQuads
May 17, 2017, 04:09 AM
That looks so clean stack But what for you would need so many uarts?
May 19, 2017, 02:59 AM
SBUS/IBUS/DSM Receiver
Smartaudio/Tramp VTX
Frsky Smartport
TX5 & RX5 on FFC socket with special purpose
May 21, 2017, 01:42 AM
Dutch RC Reviewer
Dutch 79's Avatar
Very nice, I just got one to go with this PDB https://www.banggood.com/Matek-FCHUB...&rmmds=myorder
With everything I need turned on it can run 16k 16k @20% CPU, Very nice
May 22, 2017, 05:19 AM
Hows the % at 32/32?
May 22, 2017, 07:00 AM
Dutch RC Reviewer
Dutch 79's Avatar
I didn't check with accelerometer off but when everything is on its @ 100%
May 22, 2017, 10:48 AM
BF can't support F4 @ 32K loop rate now.
May 22, 2017, 11:25 AM
Dutch RC Reviewer
Dutch 79's Avatar
Thank you, I will try with everything off and see how that works.
The accelerometer takes a big chunk of the CPU and people running @ 32k don't need that to be on.
May 23, 2017, 05:38 AM
Yes it can.
Tested one of these boards, with the hub, nice, works well. BUT the silly thin plastic locking bar for the ribbon connector is not good, it breaks after a few uses, if you lock it and never unlock fine, but if you have to disconnect for repair -
May 23, 2017, 11:42 PM
https://www.fpv303.com
FPV303's Avatar
Originally Posted by Cheredanine
Yes it can.
How's the Gyro Noise? I see it's a diff gyro than most of the other ICM's so I'm curious if this one's a bit better.
May 24, 2017, 01:13 AM
ICM20602, used on RF Revolt, SP Racing F3EVO & F4EVO.
May 24, 2017, 07:23 PM
Has anyone reviewed or made a video yet?
May 24, 2017, 09:50 PM
Matek F405 FC.. And FC hub 6s. The perfect set up? (6 min 35 sec)
Matek F405 and FChub pdb combo Maiden flight and final thoughts (8 min 47 sec)
Crazy (3 min 6 sec)
New Product BeeRotorF3 AIO (BRF3) Flight Controller (integrated OSD) Discussion Thread rctimer Multirotor Drone Electronics 1301 Sep 12, 2021 02:30 AM
New Product Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602 nitbeat Multirotor Drone Electronics 26 May 17, 2018 01:44 PM
Discussion BF3.1.5 Omnibus F4 V2 Flight Controller STM32 F405 MCU Integrated OSD Built-in 5V BEC scousethief Banggood.com 10 Sep 13, 2017 06:21 PM
New Product $25 Omnibus F4 AIO (FC + OSD) clone - Betaflight F4 Flight Controller STM32 F405 MCU lmpuIse Multirotor Drone Electronics 20 May 04, 2017 08:01 AM
