Airflow restriction theory of lift
An aircraft wing experience a lift force when moving through the air due to high pressure on the lower surface and lower pressure over the upper surface, or part of it. Various theories have been proposed as to why this occurs.
Is there a theory of lift that proposes that the blocking of airflow creates a low pressure area on the upper surface of the wing? See this diagram: https://en.wikipedia.org/wiki/Lift_(...separation.jpg It is obvious that the angled airfoil is preventing air molecules from travelling past the leading edge of the wing, thereby creating a low pressure area on the top of the wing. This is a real effect, demonstrated through experiment. |
Of course I should have been more exact. But first, a link to a similar discussion with several useful links:
https://www.rcgroups.com/forums/show...-lift-theories Wikipedia states : Quote:
From the first few milliseconds of movement of the airfoil in the air, or the first cloud of air molecules reaching the wing of a wing in a wind tunnel, the air downstream of the leading edge finds itself at a lower pressure. This is because the movement of the wing has left an empty space that has to be filled with air molecules. If the wing is moving, the space will be filled with the air molecules ahead of the wing. Will have a look at the following answers, maybe something there. Basically I am looking for a mechanical explanation of lift by referring to experimental results, without resorting to any other principles. https://aviation.stackexchange.com/q...-generate-lift |
Reason: Spelling
From NASA ... https://www.grc.nasa.gov/www/k-12/airplane/lift1.html Quote:
Not to further kick a very wounded horse, but in reference to many prior go-arounds in several previous threads please note that NASA wrote "Lift occurs" and not *ALL lift occurs" or "Lift ONLY comes from".
A fire occurs when flammable material is ignited by a match ... or by a cigarette lighter ... or by lightning ... or by spontaneous combustion Of course just as there are people who still think the Earth is flat or held up by a large man standing on a huge turtle, those refusing to understand or being unwilling to accept the fact that lift can come from many sources or phenomena .... please keep working on it (at home)
The streaklines animation, which I just viewed for the first time, illustrates the point I want to make. The lower two particles get deflected downwards by the wing. One of the upper molecules the light blue one, I think, travels along the surface of the wing, but the other two take a long arc over the top surface of the wing, leaving a large gap between them and the wing surface, illustrating the area of lower pressure.
I can accept the deflection of air by the lower surface, and the force of the impact of the air molecules on the bottor surface, however there is no way the molecules of air moving over the top surface can exert any force on the top surface of the wing, on the contrary it is the lack of force on the top of the wing by the random movment of gas molecules that results in low pressure on the top surface. Whether the air is turned or sucked up by a large vacuum cleaner makes no difference, its work is done. The question is which comes first, the low pressure on the top of the wing or the speeded up airflow over the top? I would think the former. |
Perhaps a study of why cars change contact pressure with the road would clarify or confuse the ongoing queries about lift.
The "flying Ferrari" accidents demonstrate that lift can come from many sources |
Blocked molecules
The diagram illustrates my point. The molecules of air are blocked from the top surface of the wing, in reality, viscous forces cause the air to stick to the wing. If there was no air on the top of the wing it would be even better and the pressure differential would have been even greater.
It's all very clear to me now. So maybe a little step on the top of the wing will increase lift, a la Kline–Fogleman airfoil? edit: the pressure distribution shown here http://www.mh-aerotools.de/airfoils/...tributions.htm Seems to indicate that the air is able to affect the flow of air ahead of the leading edge, in subsonic flow, anyway. Edit: this link shows the pressure ahead of the airfoil, the high pressure area must be deflecting air away from the leading edge. http://hyperphysics.phy-astr.gsu.edu...s/airfoil.html Now what does it all mean to us wing-makers. |
Reason: Info
There's a potential issue with this description of lift. Your drawing (with the air separated from the upper surface) best represents the flow around a stalled airfoil. A stalled airfoil typically generates less lift than one with the flow attached to the upper surface.
seems to be a bit of confusion about attached FLOW and reduced pressure on upper surfaces.
There can be pressure difference with attached flow and basically FLAT NOT parallel surfaces. The ice cream cone airfoil used by WExtra on many designs shows this to be true. You don't need an airfoil which is shaped differently, top to bottom. just a bit of change from zero AOA |
This isn't the correct physical explanation however. A fluid is accurately modelled as a continuous material which deforms around its surroundings. This is an accurate assumption to make as fluid particles interact with their neighbours something like 100,000,000,000 times a second. I think the best explanation for lift which gives a physical understanding of it comes primarily from conservation of mass. An airfoil doesn't impose any hard constraints on the flow but it does still constrict the flow travelling past it. The same mass of air has to leave the section the airfoil is in as entered into it (imagine two vertical lines at the leading and trailing edges). That means the air has to speed up when going past the airfoil for mass to be conserved. The larger the obstruction, the more the air will speed up. This is why a more cambered wing (or a higher angle of attack) will produce more lift, the air is forced to speed up more to get around it and by bernoulli's principle, lower pressure will accompany this. If the wing has undercamber (I don't know the correct term but imagine an umbrella) then the air is able to expand into the lower surface so it doesn't have to speed up as much to get past it thus increasing the pressure there. With all that said, no lift would be produced without viscosity. If there was no viscosity the flow would be able to turn around the trailing edge from the lower surface, and high speeds (and low pressure on the lower surface) would accompany this resulting in no lift on the airfoil. Viscosity acts to resist the deformation of the fluid so the viscous force forces the air to leave the airfoil parallel to the trailing edge. Thus preventing the lower pressure from occuring on the lower surface. The airfoil is the shape it is so that the largest obstruction is toward the front where the pressure gradient is most favourable, which helps prevent separation. I think bernoulli's principle can be understood physically as well on the level of the molecules. At a given temperature, all the molecules in a fluid parcel will have the same momentum, when the fluid parcel is stationary, the momentum is spread out in all directions and this is pressure. When the fluid parcel is moving, the momentum of the molecules is the same as this is set by the temperature, but some of this momentum is now "given" to moving with the fluid parcel reducing the total momentum of the molecules available for pressure. The takeaway from this is that higher speed doesn't cause lower pressure or vice-versa, they accompany each other Just my 2 cents after reading about this for the last few months |
If you were to put a dam against the airflow near the forward edge of the upper surface, I would expect it to to a very high pressure differential at the top of the dam (low pressure spike as the air turns the corner)and the higher pressure area of the wing aft of the dam. Which would lead to a stalled condition. Sounds like a vintage roll control spoiler. Because the low pressure is derived from a very small area, I would say that any lift achieved would be very low. Be mindful that a normal wing typically generates maximum lift just before a stall, with a very high pressure differential over a fairly reasonable area (apparently), but the area aft of that low pressure area will be slightly turbulent. When the wing nears the stall, then stalls, the turbulent area walks forward up the wing, and the wing looses lift. So, an even (low) pressure distribution, down the chord of the wing, is what you might shoot for. |
I was trying to point out that this blocking of moving particles is responsible for the lack of particles on the upper side of the flat plate in the case of the plate in space (or saucer?) and in the case of a flat plate immersed in an ocean of fair, some rarefication of the fluid occurs at the top surface. Actually, this sort of thing happens in the ocean for propellers, it is called cavitation. Quote:
It all gets easier to understand if you accept that any difference in air pressure will normalize to ambient pressure as rapidly as it can
low pressure area absorbs higher pressures and high pressure flows to lower pressures no mysteries - just rational behavior. anything that gets in the way of this attempt at equalization of pressure , gets shoved around. in this case - the wing goes with the flow. from high to low. who is this Newton guy? Wayne? |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Complaint | Please lift the silly little restriction | Genetics101 | Site Suggestions / Complaints | 2 | Sep 24, 2014 11:15 PM |
| Discussion | Obama Administration Lifts Restrictions On Cuba | Real Ira | Life, The Universe, and Politics | 11 | Apr 13, 2009 11:20 PM |
| Discussion | Theory of VTOL lift? | anchange | VTOLs | 5 | Oct 21, 2007 11:16 AM |
| Alternate lift theories | schoey | Modeling Science | 3 | Jul 31, 2002 10:07 PM | |
