I've never had a shrinking issue from any kind of nitrate dope. What are you using for covering? How light a structure are you working with? I've had fabric tighten so much it pulled huge warps in very lightly build wings.
carl |
ALL dopes, used on light weight structures (anything FF, generally, but I do it EVERY time) should be typically thinned by 50%, as it comes from the manufacturer's container, before it is applied. The smaller/flimsier the structure, the more thinner added. With practice, it is possible to judge appropriate consistency and shrinkage. When in doubt, ADD thinner!
Advertised as such, "non-tautening dopes", does not mean it wont shrink ! I fully suspect that Sig's Lite cote is simply Randolf's non-taughtening butyrate, or perhaps from Certified. It will tighten, as you are finding out. Generally, nitrate products are loosely assumed to stabilize/stop shrinking rather quickly after application. Butyrate never truly quits shrinking over its service life. Neither is permanent. Both "move" over the hours, days, weeks, and years, as they gas off, get brittle, etc. With care, both will provide adequate shrinking and sealing properties, appropriate for reason chosen. For modeling use, butyrate is considered fuel proof, but that's not an absolute, either. BTW, butyrate will cover(fuel proof) nitrate but nitrate will not go over butyrate! Thinned dope, applied in quick drying successive brush coats, builds up a shiny, smoother, sealed finish faster and better than fewer, thicker applications. Spraying dope with airbrush or small cup gun will build a finish, but takes longer. I tend to stop applying dope coats based upon reaching a desired finish, rather than a rote "number of coats". Typically, 5-6 coats of clear on tissue is considered adequate for FF gas finish, but perhaps only 1-3 coats on a P-nut? Silkspan or Silk may require more etc.By all means keep track of dope consistency and number of coats applied, when starting out, etc. It will form a basis for your own experiences and preferences. |
I haven't posted here for a while but have done some more experimentation since the last time I have. What I have decided is that I will use the Nitrate dope to seal my synthetic covering materials with one to two coats of thinned 2:1 this will not seal my covering material but I will than do that with Acrylic based varnish. This should reduce the shrinkage while providing the sealing of the material. I will be using Pellon- 830 or Pollyspan. The Pellon is more multi directional than the Pollyspan and less heat shrinkable but the weave is less porous and smoother so it fills faster. I will than use Aero-Crylic model aircraft paint for the final color finish. This is the new process I will be using for my small 1:12 scale models. The larger 1:6 scale models will not be so critical when it comes to tautening. Here is the post on the Pellon, https://www.rcgroups.com/forums/show...Is-it-possible
Thread Tools | |
Similar Threads | |||||
Poll | How much wind is too much. | FloridaFlyBob | Electric Plane Talk | 16 | Nov 29, 2016 05:55 PM |
Help! | Silk won't shrink after doping | Hoot | Painting and Finishing Tips | 8 | Nov 12, 2016 02:04 PM |
Help! | Silk not shrinking after doping | Hoot | Balsa Builders | 6 | Aug 22, 2016 12:58 PM |
Question | How to dope an under-cambered wing without it shrinking away | Sackie | Scale Sailplanes | 2 | Apr 24, 2016 07:34 PM |
Discussion | Wobble in bell housing. How much is too much? | MaxPowers5 | Multirotor Drone Talk | 1 | Feb 19, 2016 04:29 PM |
