Hobbyzone Delta Ray - RC Groups
May 14, 2017, 11:54 PM
glr
glr
Hobbyzone Delta Ray
I am new to RC flying. I have a delta ray & Spektrum DX6 controller. I can successfully bind it but the engines won't start. Do i need to do something else to get them started.
May 15, 2017, 06:25 AM
flypaper 2's Avatar
First take the props off. Set the throttle to about 1/4 throttle Then, put the throttle trim down to the bottom. If you hit the spot, you will hear a bleep and the motors will start. If that doesn't work go to the servo endpoint in the programming , and lower the endpoint till the motors start.
Gord.
May 17, 2017, 12:17 AM
Up! Up! And Away!
GottaZoom's Avatar
Throttle trim to bottom is probably it - make sure it is all the way down to bottom of its range before you try again.
If advice above doesn't work, power up TX first with throttle stick at bottom, then power up plane and hold plane still and wait for elevon dance to finish. Then try motors.
If it still doesn't work, power it up TX with stick at top (WOT) to calibrate throttle, then power up RX. Wait for dance to finish, then move stick down to throttle off, wait a few seconds, then try throttle.
See ya over in the DR thread.
May 30, 2017, 09:39 PM
noob RC
kneel23's Avatar
to get mine to work i just set throttle to 150% on the downside (default is 100%) in servo setup.
I got mine a couple years ago and didn't know what to do (they don't cover that in the manual) but I just trimmed my throttle down to 129% and even that worked.
May 31, 2017, 05:22 AM
flypaper 2's Avatar
Another way to do it, ( results in the same thing) is to have everything plugged in and set the throttle trim at the bottom. No prop on it. Set the throttle stick at about 1/4 throttle. Now go to lower throttle endpoint , and start to lower it. When you hit the magic spot the motor will give a few beeps and start running. Go a few % lower and stop. Back out of programming and you're good to go.
Gord.
May 31, 2017, 04:31 PM
Make sure the motor kill switch on the radio is in the correct position.
New Product Delta Ray RTF with SAFE Technology by HobbyZone ChuckTseeker Beginner Training Area (Aircraft-Electric) 7976 Sep 13, 2017 03:25 PM
Review Horizon Hobby & HobbyZone's Delta Ray RTF with Safe Technology Review Michael Heer Beginner Training Area (Aircraft-Electric) 35 Dec 25, 2016 05:09 AM
Help! HobbyZone Delta Ray motor issues (CRASH) FishInferno Beginner Training Area (Aircraft-Electric) 2 Sep 13, 2015 11:57 AM
New Product New Hobbyzone Delta Ray- thoughts on FPV use? MRGTX FPV Aircraft 4 Oct 17, 2014 10:01 PM
Discussion HobbyZone Delta Ray. A trainer wing. ssteven1 Flying Wings 9 Aug 07, 2013 05:01 PM
