May 14, 2017, 10:18 AM
PGR
PGR
Low AltiDude
PGR's Avatar
Stainless Steel Eye Screws ?
Can anyone direct me to a source for small stainless eye screws with a wood screw thread? I'm looking for a size that can be used on the mast and booms on a Soling 1M.
Perhaps I haven't stumbled upon the proper search term, but these have been surprisingly hard to find. I can find steel and brass eye screws, but not stainless.
Thanks!
Pete
May 14, 2017, 11:13 AM
Kevin Gault
poltergeist's Avatar
Leading Edge Hobbies in Canada has KDH brand screw eyes. I'm pretty sure they are stainless. http://www.leadingedgehobbies.com/we...t=1474&brand=0 page 3 in the list...about half way down
Kevin
May 14, 2017, 11:18 AM
vintageone's Avatar
Hi Pete, I know how difficult small hardware can be to find !!! I too was amazed not much came up when I did a search,however I did find these two ebayers selling screw eyes,perhaps these may fit the bill?? Dave
http://www.ebay.com/itm/100-Pack-3-16-Stainless-Steel-Screw-Eye-Rings-/182337991085?hash=item2a7430f1ad:g:XrUAAOSwB09YF1v B[/URL]
http://www.ebay.com/itm/Stainless-St...UAAOSw~bFWFjeX
May 14, 2017, 12:23 PM
Dick L.'s Avatar
McMaster- Carr or Fasteners Inc are two possibilities to check . Just a thought.
May 14, 2017, 01:32 PM
PGR
PGR
Low AltiDude
PGR's Avatar
  • 3/16" Stainless Steel Screw Eye Rings
  • Screw Eye 8mm
  • 10x4mm Screw Eye
What do these things mean? I've been a mechanic/machinist (vehicle & industrial) for 50+ years and can accurately identify most screw and bolt sizes with eyeballometry, but these stupid descriptions offered by hobby store and ebay retailers are uselessly ambiguous.
The trade size of the screw eyes I want are #216 and #216-1/2 and according to the Home Depot website they're available in-store in 304 stainless steel. Who knew? (I'll believe it when I see it, though)
Pete
May 14, 2017, 07:21 PM
PGR
PGR
Low AltiDude
PGR's Avatar
No joy at Home Depot. They don't even carry the Crown Bolt line that they advertise online, at least not in-store. Instead they carry the Everbilt line and they do have some stainless sizes, but not the size I'm looking for.
FWIW, they do carry the #216-1/2 size that I thought I wanted, but the wire size isn't big enough and the threaded part is too short. The threads on the #216 would be long enough, but the wire size would still be too small and H.D. doesn't stock them anyway.
Now I'm convinced that I want size #214 which may sound counter-intuitive, but smaller numbers mean bigger wire size. Dimensions for the #214 size can be found HERE and details for the #214-1/2 can be found HERE. For a Soling 1M sized boat with a wood mast and booms, the #214 should be the right size for the mast and the #214-1/2 should be the right size for the booms.
Now I just need to decide whether I can settle for brass or if I want to find them in stainless. I'm leaning towards stainless because the original eye screws that Victor provided were brass and the ones on the mast (for the stays & shrouds) bend quite easily.
Pete
May 14, 2017, 09:56 PM
Not sure if these are the correct size you want.
https://radiosailing.net/collections...deck-eyes-10pk
May 17, 2017, 02:28 PM
http://www.sailsetc2.com/store/index...fasteners.html
no eyes
but you cna use a pan head screw and then loop the shroud over it and crimp down.
you can also use tangs in place of eyes. much cleaner look IMO
http://www.midwestmodelyachting.com/...eel-_p_60.html
I have no screw eyes or tangs on my booms or mast. thru drilled. if you join the soling one meter yahoo group there are hundreds of pics. with I thin one gallery set up just for mast/booms
I did use tangs for my lower spreader attachment and forestay. I'll take pics when I get home and post. I don't use the diamond
May 19, 2017, 05:24 AM
pics as promised
so in the front of jib club is not a screw eye its a cotter pin drilled and glued in place. and there is one screw eye on the main where the vang attaches
May 20, 2017, 06:45 PM
PGR
PGR
Low AltiDude
PGR's Avatar
OSH (Orchard Supply Hardware) has 214 & 216 screw eyes in solid brass. It's not stainless but it won't rust.
Discussion Cap or button head screws? Stainless steel or Hi-Tensile? LaurenceGough Off-road Cars 3 May 14, 2008 03:21 AM
Question Trex stainless steel screws enrico74ec Mini Helis 3 Sep 13, 2006 09:40 PM
