May 12, 2017, 12:56 PM
New Product
MinimumRC Spacewalker 460mm Wingspan Balsa Wood Laser Cut RC Airplane KIT
Specification:
Brand Name: MinimumRC
Item Name: Spacewalker
Type: KIT, KIT with motor(optional)
Wingspan: 460mm
Length: 380mm
Material: 1mm Balsa wood + 1mm laminate
Flying Weight: 35g
Package Weight: About 160g
Recommended Parts (Not Included):
Motor: 716 coreless, Click Here
Servo: 1.7g *2, Click Here
Receiver: Micro 1s 4CH receiver, Click Here
Transmitter: 2.4G 4CH, Click Here
Battery: 1S 3.7V 150mAH 1.25 JST
Note:
The KIT verison doesn't include any electronic device.
The KIT with motor version comes with a 716 coreless motor and a 138mm propeller.
Please select the version you prefer.
Install Manual, Click Here
Package Included:
1x MinimumRC Spacewalker 460mm Balsa Wood Laser Cut RC Airplane KIT
https://www.banggood.com/MinimumRC-Spacewalker-460mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1151157.html?rmmds=category
May 12, 2017, 12:57 PM
Seems awesome
Jun 24, 2017, 07:59 PM
I just built one. As soon as the wind stops blowing, I'll fly it and report back. It's a neat little kit. I covered mine with tissue paper and dope.
Aug 21, 2017, 04:22 PM
I'm also building this kit at the moment with UMX AS3X bricks. The instruction manual did not say where the CG is. Does any one know? Thanks.
Sep 19, 2017, 08:01 PM
I just ordered one of these from banggood and it says two servos are required but it seems to me that it would require 3 for the aileron, rudder and elevator. Also, did either of you ever fly and how do you like it? This is my first rc plane and hopefully it will be a good one to learn on.
Oct 09, 2017, 02:43 AM
I finished my Spacewalker with UMX AS3X bricks, 180 3000kv 2cell brushless set up. It flies like a charm. Great power even in the light breeze. Inverted, loops, rolls, it handles pretty well. Wing loading is low on this thing. Its a floaty flyer. Iím pretty happy with the build.
BTW, the CG is on the front set of the wing spars.
Apr 25, 2018, 05:52 AM
Can you talk about what finish you put on this plane, and what power and radio setup you used? Banggood links would be massively appreciated.
Apr 25, 2018, 10:05 AM
Power setup is really the gutted kit from a 2S UMX micro. I bought them from the Micro/Indoor classified. Those 2S UMX AS3X kits pop up in that classified all the time at good price. No need to buy them new. But links are here. Essentially, UMX AS3X Pitts, Revolution, Waco power kit can all work. Spectrum radios can work.
AS3X board
https://www.horizonhobby.com/dsm2-6-...l-esc-eflu4864
180 Outrunner
https://www.horizonhobby.com/bl180-b...kv-eflum180blb
2S 280mAh Lipo
https://www.horizonhobby.com/280mah-...-p-eflb2802s30
2 Gram linear servos for ailerons
https://www.horizonhobby.com/23-gram...rvo-spmsa2030l
Covering is Solite/Monocote iron on film.
Apr 26, 2018, 09:04 AM
AS3X board
180 Outrunner
2S 280mAh Lipo
Thanks so much for the info! Unfortunately I live in Taiwan, so Banggood is probably my best bet, but this gives me search terms I can use
Mar 11, 2020, 03:03 PM
The runway used to be longer
Mad_Mike's Avatar
Hi guys:
I finally got mine done.
I was waiting for electronics and lucked into a busted Indoor Parkzone Corsair at auction for $3, since it came with a nickel for nose weight my investment dropped to $2.95.
I sprayed a super light coat of red on the wing and yellow on the fuze.
It weighs 45g so 10g over. I'm not sure why it's so much over but the 220mAh battery and double wing servos don't help.
Today began with almost no wind so I went flying and got GoPro video. This plane flies amazingly well!
It was -2C and tiny batteries don't like that but I got 3 minutes with probably 1 more minute left in the battery.
The build is very fiddly, I had to wet most of the curved balsa. The balsa is Laser cut perfectly but the plywood has to be adjusted to fit almost everywhere.
I recommend this kit to experienced builders only.
3-1/2 minute Video here.
New Product MinimumRC Fokker E3 420mm Wingspan Balsa Wood Laser Cut RC Airplane--FREE TEST BG Tobey Micro Ready-to-Fly 16 Mar 31, 2018 12:17 AM
New Product MinimumRC Fokker E3 420mm Wingspan Balsa Wood Laser Cut kit Drra Scale Kit/Scratch Built 1 May 10, 2017 03:18 PM
New Product Flying Tigers P40EP Balsa Wood 860mm Wingspan RC Airplane KIT Drra Balsa Builders 2 Sep 12, 2016 12:27 PM
Discussion Laser Cut Wood Model (KIT) ACCHOBBY Chit Chat 1 Jul 18, 2016 10:21 PM
Question looking for someone to laser cut balsa ribs for new kit jarel design CAD/CAM 3 Jun 24, 2016 08:06 PM
