May 12, 2017, 07:04 AM
Dirty Birdy ARF
Just purchased NIB and am assembling parts to build this beauty! Looking for any tips! I welcome any an all advice as I'm retuning to flying after 45 year hiatus
Will be Electric cause it fits my lifestyle and my starter planes.
Please suggest ALL Mods. cause I want to keep it flying. The fuselage just past the wing feels a bit weak! Thoughts?
Thanks and look forward to the input!
May 12, 2017, 09:25 AM
DavidsPlanes
doxilia's Avatar
Try an Electrifly Rimfire 60 on an APC 12x9/13x8e prop. 6s5K LiPo. Amazing power (~1.8-2.0 KW)!
Electric trike retracts of course (because they'll hold up in the absence of vibration). You can use E-Flite 25-46 units. They're fine on 4 mm struts.
Never had the ARF so can't comment or suggest further on that front. However, if the tail boom is "soft", you can add a pair of thin 1/4" strips of CF down the sides and epoxy them in with ZAP finishing resin. Once cured the boom will be much stiffer.
Brief absence... Welcome back to the fold!
David
May 12, 2017, 09:41 AM
AMA 32832 - SPA L27-VRCS 1138
Dave Swanson's Avatar
The old Dirty Birdy ARF thread on RCU has quite a bit of good information. One of the guys did a electric conversion starting on page 15 with sporadic updates then on that you may find useful.
http://www.rcuniverse.com/forum/clas...dy-arf-15.html
May 12, 2017, 10:18 AM
DavidsPlanes
doxilia's Avatar
You might find this post helpful too:
http://www.rcuniverse.com/forum/clas...l#post11067420
and this review thread:
https://www.rcgroups.com/forums/show...-60-ARF-Review
David
May 12, 2017, 11:56 AM
A man with too many toys
EP Conversion
How do you guys recommend making a battery hatch. I have a couple of old nitro pattern ships with fiberglass fuselages (including the GP Dirty Birdy ARF). I would like to see what others have done before I start cutting on that beautiful fiberglass fuselage.
May 12, 2017, 01:09 PM
DavidsPlanes
doxilia's Avatar
Take a look at Doug's Conquest IVe electric conversion thread on this forum. There are details on making a LiPo access hatch out of the glass canopy section.
David
Wow RC Man, just noticed - 22.7K posts on RCG since 2001! That's serious...
May 12, 2017, 03:04 PM
Thanks will do. Having the forum makes the hobby have a new dimension!
May 12, 2017, 03:31 PM
Raised on 80's Pattern
Fatherof4's Avatar
https://www.rcgroups.com/forums/show...d-Thread/page6
Doug
May 12, 2017, 06:39 PM
Jet_Flyer's Avatar
If you sort though the Dirty Birdy ARF thread on RCU they found that the fiberglass used in the fuselage has some unusual properties that causes it to cave in on its self. If you decide to cut the fuselage you might want to be carful how you support the cut out area.
May 12, 2017, 07:50 PM
To stiffen the fuse sides, I used two pieces of firm 1/4 x 1/2 balsa, long enough to span the distance from wing T.E. to near stab L.E.
I cleaned as well as I could the inside of the fuse sides with alcohol and then spread a good layer of epoxy on the flat side of the balsa strip. With the fuse lying on it's side on the bench, I laid the flat side of the balsa strip on the inside of the fuse and used lengths of 1/2 x 1/2 steel key stock to hold the strip in place until the epoxy cured. One strip per side.
Repeat for the other side.
Seemed to help.
May 13, 2017, 05:33 AM
Seemed to help.
Do you have some photos?
May 13, 2017, 05:52 AM
Sadly, no.
Biggest problem is access to the fuse interior
Article Dirty Birdy Sport/Pattern .60 ARF Review CSpaced Classic Pattern Flying 147 Feb 25, 2019 12:03 AM
Help! Great Planes Dirty Birdy ARF Cowl jwellsmusic Classic Pattern Flying 0 Mar 20, 2017 10:07 AM
Discussion GP Dirty Birdy Arf Cowl NIB-SOLD! Vertigo II Classic Pattern Flying 2 Mar 24, 2016 11:47 AM
Discussion GP Dirty Birdy ARF Build issue Lumpy05 Classic Pattern Flying 38 Feb 09, 2013 10:25 AM
New Product Great Planes, Dirty Birdy .60 ARF !! Pitstop000 Classic Pattern Flying 100 Jun 12, 2012 01:52 PM
