This thread is privately moderated by neonext FPV, who may elect to delete unwanted replies.
May 12, 2017, 03:44 AM
neonext FPV's Avatar
Mini-Review
HS1177 Clone 19$- 600TVL 2.8mm Lens 1/3" Sony Super Had II CCD Camera
Grab yours on Link ( Promotion Sale From May 11 to May 22 only 18.13 $ on Banggood.com )
600TVL 2.8mm Lens 1/3" Super Had II CCD Camera is exactly the same camera as Foxeer HS1177. It come with IR Block, 2.8mm lens and it has exactly the same configurable OSD menu and function. Very nice clone of popular HS1177. Besides the orginal HS1177, I have this clone and if I compare it with original one the performanse and image quality is exactly the same.. Clone uses same chip like HS1177.. It is cheaper about 12$ , plastic case is same dimensions and the plastic quality is good... I suggest that you put little hot glue on CCD legs becouse if you hit hard the chip leg can bend. I had exactly the same problem.. But that was frontal shot in the tree :-) :-)..
Package Included:
1 x Camera with 2.8 Lens
1 x Mounting bracket
1 x Camera cable with Male Servo end
1 x OSD Joystick cable
Description:
CCD: 1/3 Sony SUPER HAD II CCD
DSP model Nextchip 2040
Pixel: NTSC 768(H)494(V)
TV System: NTSC/PAL
FOV: 120 degree
Resolution: 650TVL(b/w), 600tvl(color)
Synchronization: internal synchronize
Shutter Speed (CCD IRIS): NTSC: 1/60~1/100000 sec
Noise: > 60 (AGC OFF)
Video Out: 75ohm, synchronize
Min. Illumination: 0.01Lux
Auto Gain: Off/Low/Mid/High
Back Light Compensation: (BLC) Off /Back light compensation/ Strong light suppression
Private shading: (PRIVACY) 1~8 private shading area
Motion Detection: (MD) On/ Off (Multi level sensitivity settable)
Auto White Balance: Manual / Auto / Auto track
Mirror: Horizontal Mirror optional
Negative: Positive / Negative optional
Color to B&W: Auto
DNR: 2DNR
WDR: D-WDR
Day / Night Shift: Auto/ Color/ B&W
Menu (OSD): English menu
White Dot Repair: Support
Image Adjustment: Support
Camera Title: Support
Power Requirement: DC5V~22V
Working Temperature: -10 C ~ 50 C
Working Humidity: 20~80%
Storage Temperature; -40 C ~ 60 C
Storage Humidity: 20~95%
Dimensions(mm): 25X25(W*L)
Weight: 14.6g(with bracket)
Power Consumption: 70mA
Features:
2.8mm Lens
IR-Cut for daylight use
May 12, 2017, 04:15 AM
600TVL 2.8mm Lens 1/3" Sony Super Had II CCD Camera test recorded with DVR and 600mw Eachine TX
On this video I used 2.1 Lens . If you fly freestyle 2.1 lens is better to use , becouse field of view is wider...
EACHINE TS5828L 600mw 58G mini Test (3 min 33 sec)
May 12, 2017, 04:34 AM
My camera setting for HS1177 and HS1177 clone
New Product Original HS1177 V2 - NOW Cheaper than a CLONE nitbeat FPV Equipment 47 Sep 09, 2017 02:37 PM
Discussion FOXEER HS1177 2.8mm 1/3 Inches SONY 600TVL FPV Camera GeekBuying Geekbuying.com 0 Aug 19, 2016 04:29 AM
Discussion Help with camera - HD 700TVL sony Effio 960H Exview HAD CCD II 2.8mm teknokraze FPV Talk 0 Jan 04, 2016 02:26 PM
Help! 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens not working bighead93 FPV Equipment 18 Jan 10, 2015 11:01 PM
Help! How to hack 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens seearestacey FPV Talk 1 Jun 04, 2012 02:22 PM
