Aurora 9X + DJI S900 + A2 + LightBridge 1 I can't bind it!!! Help! - RC Groups
May 11, 2017, 09:22 AM
Help!
Hi I get second hand S900 with Aurora 9x TX optima 9 Rx I can't bind it with the A2 trough LightBridge 1 I don't know what is wrong, maybe I am missing something with the control setup. I think that it connect via trainer port config via to LightBridge and Dbus receiver on DJI A2. I need to put in the air to test it I have not gimball right now. I make a cable to power the LightBridge Air module and its ok due it show me video signal 8 (no video image obviuosly) so it connect. I do the cable for the remote to. How can I activate the trainer port in first place for this config.?
Attached cable that I do by myself!
May 11, 2017, 11:33 AM
Xpress..'s Avatar
If the receiver you are trying to link to the Aurora 9 doesn't operate on any Hitec AFHSS protocol then you will be unable to link it to the Aurora 9, unless you have some kind of aftermarket module installed or plugged into the transmitter which I will not be able to assist you with.
May 11, 2017, 10:51 PM
Thanks for reply
Thanks for the prompt response these remote controls were connected to the DJI lightbridge system through the training port of the Aurora 9X controls with the cables that come with the DJI system --> Aurora remote --> trainer port cable phisically connect to --> LightBridge ground transmitter ---(air)- -- > DJI LightBridge air receiver on the hexa ---> A2 DJI . It has a profile in the control with the parameters of the DJI S900 hexacoptero. I would like first friend how to properly activate the training port. Anyway I gonne to do a youtube video for explain me better ! Thanks again I really like these controls I want to use it with this machine. Thanks in advance!!! I have Optima receiver 9 if that help
Image attached is to show the cable and lIghtbridge the remote control that we are talking about is Aurora 9X...
May 12, 2017, 12:33 PM
Xpress..'s Avatar
You will need to setup the Trainer function in the transmitter and then assign a switch to enable it. From there it should output the controls through the trainer port but keep in mind it will only be the 4 basic controls (pitch, roll, yaw, throttle).
Discussion Can the Flyzone Micro Calypso Glider bind to the Aurora 9X Tx? bikergeek Electric Plane Talk 2 Mar 29, 2017 11:17 AM
Discussion Dji S900 A2 controler binding problem trelobyte Multirotor Drone Talk 0 Jun 30, 2016 06:59 AM
Help! DJI Lightbridge doesn't bring A2 into failsafe Copter freak Multirotor Drone Electronics 0 May 29, 2016 01:01 PM
Discussion Help!!! please! DJI S900, A2, LB2 and Summer air gimbal Hawkeye91 Multirotor Drone Talk 0 Apr 27, 2016 05:57 AM
Discussion S900 A2 - will Lightbridge work with my GH2? AdamWatkin Multirotor Drone Talk 0 Jan 17, 2016 12:19 PM
