May 10, 2017, 10:28 PM
We Help You Fly :)))
rotorsupport's Avatar
New Product
Eachine E708 & Eachine E70 Quadcopters with GPS
Eachine just announced these two new quadcopter ..
the first one is the Eachine E708
https://www.banggood.com/Eachine-E708-Headless-Mode-2_4G-4CH-6-Axis-LED-RC-Quadcopter-RTF-p-1150487.html
Description:
Brand name: Eachine
Item name: Eachine E708 RC Quadcopter
Frequency: 2.4G
Channel: 4ch
Gyro: 6 axis
Product battery: 3.7V 550mAh (Included)
Transmitter battery: 4x AA battery (not included)
Charging time: 80mins
Flying time: 8mins
R/C distance: 50-80m
Color:White
Material: Electronic Components,Plastic
Product size: 31.5x31.5x6cm
Package size: 42.5x24.5x10.5cm
Features:
With Headless Mode,no need to adjust the position of aircraft before flying .
With One key to return function makes it easily to find the way home.
2.4GHz Technology Adopted for Anti-Interference.
4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360°.
6-axis gyro which can have more stable flying and be easy to control.
It have 3-level flight speed to switch that can make more fun with the flying.
It can realize 3D tumbling 360°rolling in four directions with 4 LED lights.
The quadcopter fuselage is made of high strength and resistant engineering plastics,lightweight and durable resistance.
Function: Up/down, Forward/backward, Turn left/right, Sideward flight, LED Light, Headless Mode, One Key Automatic Return
Second one is the Eachine E70
https://www.banggood.com/Eachine-E70-Mini-Headless-Mode-One-Key-Return-3D-Flips-2_4G-4CH-6-Axis-LED-RC-Quadcopter-RTF-p-1150488.html
Description:
Brand Name: Eachine
Item NO.: E70
Frequency: 2.4G
Channel: 4ch
Gyro: 6 axis
Color: Black
Product battery: 3.7V 250mAh 25c (Included)
Transmitter Battery: 4*1.5AAA (Not Included)
Charging time: 60mins
Flying time: 7-8mins
Quadcopter size: 13.5 x 13.5 x 4cm
Package size: 21.5 x 11 x 17.5cm
Features:
• With Headless Mode, no need to adjust the position of aircraft before flying.
• With One key to return function makes it easily to find the way home.
• 2.4GHz Technology Adopted for Anti-Interference.
• 4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360°.
• 6-axis gyro which can have more stable flying and be easy to control.
• It have 3-level flight speed to switch that can make more fun with the flying.
• It can realize 3D tumbling 360°rolling in four directions with 4 LED lights.
• The quadcopter fuselage is made of high strength and resistant engineering plastics, lightweight and durable resistance.
• Charging Cable with Protection Board.
Function: Up/down, Forward/backward, Turn left/right, Sideward flight, 3D Flips, LED Light, Headless Mode, One Key Return, 3 Speed Mode
May 11, 2017, 01:48 AM
Pixelpeter's Avatar
Both these quads look non GPS to me
That Eachine E708 looks a lot like a simplefied and brushed version of the upcoming Bugs 2; you can even see the 'chin' where the camera is positioned in the Bugs 2. Controller is also exactly the same.
The Eachine E70 looks very 'Hubsan'.
May 11, 2017, 08:09 AM
the first one is non GPS .. second one might be , or might not be using GPS ..
all these chinese companies are copying from each other .. so never mind the shape .. same shape same performance , cheaper price
May 11, 2017, 09:12 PM
Both quads are recruiting testers to review. Do you want to try? Pls PM me ASAP!!!
May 11, 2017, 11:13 PM
PM sent
May 11, 2017, 11:29 PM
Leo
Coreless for both, looks like it
May 12, 2017, 12:14 AM
Definitely going to get the Eachine E70 for my son!! Very good price point as well. I would love to test but i am too much of a newbie on these forums so good luck to the testers.
May 12, 2017, 01:38 PM
it is coreless ..
mentioned on the photos
May 15, 2017, 01:37 PM
It looks good, and the price is reasonable as well. I'd like to be a tester! PM sent!
May 16, 2017, 01:59 PM
you have 2 posts only .. hopefully they will accept you
May 24, 2017, 09:03 AM
t00nz843z's Avatar
Eachine E708 Bugs2 Clone Drone Flight Test Review
This quadcopter is a MJX Bugs 2 clone in shape only. It has no GPS, no camera, and brushed 7x20mm coreless motors. But still, it is a fun little flier.
and here is its flight demonstration
Eachine E708 Bugs2 Clone Drone Flight Test Review (12 min 34 sec)
Pros
- Shaped like the soon to be released MJX Bugs 2. It even includes similar stickers. Was this made by WLToys?
- Good basic quadcopter for learning to fly in beginners rate, and maneuverable sport flying in intermediate rate.
- Includes headless mode and one key return.
- Great range of at least 100 meters.
- Long flight time of over 8 minutes (I got 8 1/2).
- Uses widely available 3.7V 550mah battery (Syma X5C batteries).
Cons
- I needed to hold the flip button down on mine to activate the flip feature.
May 24, 2017, 09:15 AM
i just got the notification on youtube and am watching your review about it
May 25, 2017, 09:23 AM
t00nz843z's Avatar
Eachine E70 Micro Sport Drone Flight Test Review
This cheap micro quadcopter would be a great beginner's learn to fly, and intermediate sport flier.
Eachine E70 Micro Sport Drone Flight Test Review (8 min 26 sec)
Pros
- Easy to fly in beginner rate, somewhat sporty in intermediate, and insane yaw (but not really flyable) in expert rate.
- Lightweight 250mah gives it 5 1/2 minutes flight time.
Cons
- Expert rate is more for show with it's crazy yaw. But it's not really controllable in expert rate. Mainly for spinning in hover to impress an audience to your flying.
- In a post-review check flight in my kitchen, it took 19 seconds to shutdown the motors after the transmitter was turned off. Definite flyaway issue if you fly at the edge of its reception. You want to keep this one relatively close when flying.
May 25, 2017, 10:06 AM
Pixelpeter's Avatar
Did I miss the 'switch off the E70 controller and let's see what happens' test?
May 25, 2017, 10:52 AM
t00nz843z's Avatar
Sometimes I forget. Hold on, I'll do a quick check here in the kitchen.
Good catch! It took 19 seconds to shutdown after the transmitter was turned off. Definite flyaway issue if you fly at the edge of its reception. You want to keep this one relatively close when flying.
Discussion Eachine Mini APM V3.1 Flight Controller With GPS Module Danq0 Multirotor Drone Talk 0 Sep 16, 2015 11:07 PM
Discussion LOTUSRC T580P+ with GPS Quadcopter (Folding design)GPS Edition aopen3434 Multirotor Drone Electronics 5 Sep 22, 2012 05:08 AM
