This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
May 10, 2017, 09:24 PM
Gary Chen's Avatar
New Product
1080P 30X Optical Zoom Camera Sky Eye-30HZ
Hi everyone,
Sky Eye-30HZ is a gimbal designed for 30X zoom camera for drone aerial inspection,surveillance,rescue and research mission,which can be easily installed on any multirotor platform.It consists of 1080P 30X optical zooming camera and a 3-axis high stabilized gimbal,which is able to take and record 1080P 30fps video to an on board TF card, giving you a stable eye in the sky that can be controlled via drone pilot or a secondary individual allowing for an overhead view that can cover a large amount of ground quickly and effectively. The 30X zoom function will allow you to remain at a distance yet zoom closely in on anything that requires your attention.
One big feature for Sky Eye-30HZ is that it can be equipped with an Auto Object Tracking Module(AOTM),which will enable the pilot to track moving objects very easily.
Sky Eye-30HZ provides an outstanding wiring hub design for RC receiver and video output port(AV and HDMI),which makes wiring pretty easily.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Sky Eye-30HZ has two video output ports,HDMI(1920*1080*60fps ) and Analog,which makes it possible to use traditional analog 5.8G video downlink or HD video downlink.The photo/video/playback functions can be chosen by a 3-gear switch on your radio.
Features
1)590grams,light weight
1)1/3 inch 3MP CMOS sensor
2)30X optical zoom,CVBS and 1080P/60 HDMI output for video downlink
3)1080P/30 H.264 video recorded for on-board TF card
4)Auto object tracking(Optional)
5)PWM control and serial command control
6)Convenient wiring hub for RC receiver and video output(AV and HDMI)
7)3-aixs high stabilized gimbal system
8)Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
Video footage
Sky Eye-30HZ 1080P 30X Zoom Camera (1 min 9 sec)
More information
http://www.yangdaonline.com/sky-eye-...x-zoom-camera/
Latest blog entry: 4K EO/IR gimbal for drone
May 16, 2017, 05:16 AM
Gary Chen's Avatar
Auto object tracking module(AOTM) for Sky Eye-30HZ is released.
It is developed based on military grade tracking module,can easily capture and track moving object,makes the zoom camera an ideal tool for aerial inspection and surveillance.
Video footage
Auto Object Tracking Module Ground Test (0 min 21 sec)
Jun 07, 2017, 11:15 PM
Gary Chen's Avatar
Good news!
Sky Eye-18HZ and Sky Eye-30HZ zoom camera are now fully compatible with DJI Matrice 600 Series with the help of Remote Controller Channel Expansion Kit: one RC control ALL(drone+gimbal+camera)!!
New Product 1080P 18X optical zoom camera Gary Chen Multirotor Drone Talk 8 Jun 07, 2017 11:12 PM
New Product 1080P 18X EO/IR dual sensor zoom camera Eagle Eye-IV Gary Chen Multirotor Drone Talk 1 Apr 24, 2017 10:11 PM
New Product DJI M100 with 30x optical zoom hdworld Multirotor Drone Talk 6 Mar 15, 2016 02:06 PM
