Joiners
We, Randy West and I, have tried about every combination of joiners possible. Randy has 3D printed some as low as 5 degrees and up to 8.5 degrees. We have center joiners at 4 and 6 degrees. The 6 degree center joiner with the stock 7 degree tip joiners is my go to set up for my Super Light and Light. For the Windy I have stayed stock at 4 degree center joiner and 7 degree tip joiners. I don't get that much opportunity to fly in wind so there hasn't been much experimenting with different combos on the Windy.
Regarding which plane to buy, I'd say buy for the conditions you fly in most. Here, we usually have very little wind and light lift conditions. This calls for very light planes. Most of our guys have something in the low 40 ounce range. For any wind conditions the Light can be ballasted 10% of the weight with good safety margins and improved wind performance. Then there's the Windy for those occasional crazy days. Interestingly, I've found my Super Light to be good up to 10 mph winds. It is really my primary plane now. Regarding the short boom, honestly, I didn't bond with it. In all fairness, I only have about 20 flights on it so I may try it some more and play with the set up. I believe Randy shares those thoughts on it as well. You won't be disappointed with any Volo. Buy for your conditions, don't add unnecessary weight in the build and you'll have a top notch competitive plane. Darwin N. Barrie Chandler, AZ Team Futaba |
Edit...post above popped up when I posted and refreshed the page, and it answers everything. Thank you!!!
Unfortunately where I live is usually high wind and low lift, and I’ve yet to find a perfect combination for those conditions! |
Although I don't have any experience experimenting with different angle tip joiners, from what I understand, the higher angle joiners get blown around more on landing approach, especially during crosswind landings .
I guess it makes sense, if you have more tip panel up there in the air, and a crosswind, it's going to affect its flight path, at least more than a shallower angle polyhedral. As I said, I haven't verified this, but something to consider if you're experimenting with different angles. Try some crosswind landings and see if it makes a difference. -- Greg |
In high winds and ballasted you will need more power so the long tail boom is the way to go. I also replace the carbon elevator push rod for a steel one adds tail weight and durability. Now flying the short tail boom vs the long. Only in my mind are they different. |
Volo Flight Report
I have finally joined the F5J world. Finished my Volo and flew it for the first time yesterday. The model is very impressive. First launch was 80M and the flight lasted 20 minutes. Even though there are hundreds of posts on how great these new breed of models fly, you have to experience it to appreciate it. It goes up on nothing and covers ground so much better than I thought a 48oz model would. I can't wait to get some more airtime. Having been a longtime F3J/TD guy it was fun to fly something that is so light yet has great performance.
I also want to say that its been a pleasure dealing with Oleg. He monitors this thread and is quick to respond. The questions I sent him via email were always answered in a timely manner. Stats: 48oz RTF MKS 6130 Flaps Spektrum 7020 on ailerons Blue Bird on Elevator and RUD Tenshock motor RFM 13x8 Prop Hyperion 850mAh Castle Creations Talon 60 Battery backup by Garry Ogilve The only real change I made was using some 1/16" aluminum tubing I was able to make some pushrod ends that were adjustable before gluing in place. See attached pictures. Like others I installed the RX just in front of the tail servos on 2 rails that are glued to the servo tray. Jim McCarthy |
Jim, thanks for the report!
It is very rewarding to have a positive report from a 'distinguished' TD pilot. ![]() We need more pictures though ![]() |
Latest blog entry: NOT AVAILABLE currently, sorry! DLG...
Just before his maiden with the new baby!
Thanks, Garry! Nice field you guys have there!
Jim, you need to install a rubber band on the prop to keep the blades folded all the time, your glide ratio will improve some more! Also, I noticed how you notched the fuselage wall a little near the servo arm. You need to watch this place for potential cracks developing. The cone where the servos sit is a highly loaded structural element, the tail boom is cantilevered on it. We already weaken it somewhat by making the opening on top for the servos. This place is subjected to shock bending loads during landings. If the wall(s) crack, it is nearly impossible to see the damage before the next launch. And then the boom may deflect a little before/during the flight, and the plane will develop a lot of down trim. Sometimes even during the motor flight. Sometimes so much that you cannot pull out of a dive... |
Yes this area has extra layers for sure.
[QUOTE=foxcraft;43196877]Oleg,
Hasn't the manufacturer taken into account the weakness of the rudder/elevator mounting area and reinforced this with additional carbon wrap in the making of planes going forward? Lou[/QUOTE Yes Oleg informed the factory early on when he/we got the first two and my cracked on a hard landing. My experience was not so much where Jim put the notch for the servo arm at but at the step down inside the aft half of the tail boom. The new versions there is almost no step on the inside. When it would crack it would usually happen right along the line and hard to see or notice before the next flight. If you hear something crack on a hard or sideways landing just take the time to un tape and check it over before flying again. I have really pounded my latest two Volos with no cracks and no modifications to the joint area. Although this still remains to be an area that needs checking on a hard landing and if you think you are going to dork for points then it's a good idea before installing the servo tray to add an extra layer of carbon on the inside just in case. The wing tip joiners I think are also a little stronger, or I am just landing much better. The idea is that they will crack or break instead of the wing mashing works very well. I have only snapped a couple of tip joiners with no wing damage over hundreds of landings. |
My Volo Standard arrived today. What a STUNNING F5J model! The fit and finish is truly impressive. Thanks Donatas and Oleg!
Mine came with the Servos (MKS HV6110 on Ail/Rud/Elev and MKS HV6130 on Flaps) and IDS installed at the factory + all wiring done. Still waiting on motor : I am thinking of going with a Tenshock EDF TS-EZ1515 15T 3770KV with 5:1 PG. My LiPo's are in Ogdensburg (4S 850's and 3S 850's), I'll be picking those up tomorrow morning. Haven't figured out which props to go with yet (suggestions always appreciated!). Graupner ESC and Rx ( you'd almost think I'm a Graupner Team Pilot or something ![]() Weights (with servos and wiring installed) Right Tip: 134g Left Tip: 129g Right Shoulder: 257g Left Shoulder: 256g Rudder: 26g Elevator: 26g 6deg Spar: 49g 4deg Spar: 49g 7deg joiner: 12g 9deg joiner: 14g Aluminium motor mount: 4g Total: 893g (no motor, spinner, props, ESC, Lipo or Rx) sorry- I have no idea what that translates to in non-metric. The cold has arrived as has that nasty white stuff on the ground which means I won't have the chance to maiden the Volo until the Spring sometime ![]() Jean |
Thread Tools | |
Similar Threads | |||||
Discussion | Aloha F5J from JimAero | pguim | Electric Competition Soaring-F5J/F5K/ALES/E-Soaring | 215 | Jul 05, 2019 06:39 AM |
Discussion | Taser F5J (carbon) from Soaring USA | airporter | Electric Competition Soaring-F5J/F5K/ALES/E-Soaring | 2 | Oct 25, 2016 12:27 PM |
Discussion | E-volo takes first (public) manned flight | CactusJackSlade | Multirotor Drone Talk | 3 | Apr 10, 2016 05:47 AM |
Discussion | Volo pdb issue. | deekon | FPV Equipment | 8 | Oct 22, 2015 09:31 PM |
Discussion | Volo pdb issue. | deekon | Multirotor Drone Electronics | 1 | Oct 11, 2015 11:43 PM |
