Dec 01, 2021, 02:49 PM
over it
Launched my superlight the other day with the tail servos unplugged. When I put the flight pack in I must have pulled the wires out of the Rx...fortunately the elevator was neutral but I noticed immediately when I lauched and the elevator compensation wasn't working so I shut it down at 20 something meters...flew it with flaps and ailerons to the ground to no damage...lucky me
Dec 01, 2021, 03:22 PM
Screwing up is an art
mabrungard's Avatar
I'm liking the single plug approach that Oleg showed with early in this thread where his Rx is mounted in the boom and there is a single, multi-pin plug that connects all wires at once. I use a 1x8 connector that carries power, esc, ailerons, flaps, and Sbus. I have colored stickers on one side of the male and female connectors to help prevent me from plugging the system in backwards.
Dec 01, 2021, 04:14 PM
RV7guy
dnbarrie11's Avatar
SBus
I generally run 100% SBus using only 2 ports on a 4 port receiver. Saves weight and wire pollution. I recently built a new boom and used KST X08's. This required a wire run to the receiver for the Rudder and Elevator servos. I did as described earlier for the connectors.
I have one Volo with the receiver mounted on a tray attached front of the boom. Works great. But we almost always have to add weight to the nose. So no practical advantage.
Darwin
Dec 01, 2021, 04:21 PM
over it
I don't understand how the rx in the boom would work out...seems the Volos try real hard to come out tail heavy...guess you could compensate with a larger battery/motor/ whatever but that's just adding unnecessary weight
Dec 01, 2021, 08:47 PM
a different approach 😉
Dec 01, 2021, 09:08 PM
ransamuels's Avatar
Ron: Tell us about the pushrods. Do you have a connecting function? Or did you make it a one piece fuse?
Dec 01, 2021, 09:24 PM
iumop ap!sdn w,I
G.P.'s Avatar
Is the added weight of the longer pushrods less than what the required nose weight would have been?
Latest blog entry: Colour Schemes
Dec 01, 2021, 11:11 PM
One piece fuselage.
Moving the servos ahead of the CG allowed me to use a light weight power set up and reduce the overall weight .
Ron
Dec 02, 2021, 09:14 AM
ransamuels's Avatar
"and reduce the overall weight ."
C'mon Ron ... tell us how much weight was reduced."
Dec 02, 2021, 09:16 AM
mabrungard's Avatar
I didn't have to add nose weight for either my Std or Lt. The Std uses the Tenshock 1515-13 geared and the Lt uses the Xpower 2919 direct. In the case of the Lt, I have to be careful to NOT insert the 850 Lipo too far forward or the CG will be nose-heavy. I do have to make sure the 850 is all the way forward on the Std. But still no accessory balancing nose weight needed for either plane.
An important consideration is that the Rx is very light and its not very aft. That probably helps avoid adding much in the way of tail weight.
Dec 02, 2021, 05:02 PM
ransamuels's Avatar
I had a crash today and broke up my front fuse and joiners. If anyone has a front fuse and/or joiners to sell please let me know.
Robert Samuels ..... [email protected] or 314/477-6778
Yes, I did put in an order with Oleg. I'm just working all venues.
Dec 02, 2021, 05:40 PM
D T
D T
D T's Avatar
I have 5 or 6 tip joiners, Strong layup. Think they are 7 deg.
Sold my Volo last year...
Dec 05, 2021, 11:32 PM
Oleg Golovidov
olgol's Avatar
Another great day at the club field with the members of the NC Volo society
Dec 07, 2021, 12:49 PM
Oleg Golovidov
olgol's Avatar
Huge thanks to all Volo pilots representing the Volo brand at the AZ event!
Congrats to my Volo pilots who made the fly-offs.
Special congrats to Steven Willcox for placing 2nd both in the prelims and the fly-offs!
And to Josh Freund for placing 3rd in the fly-offs!
According to my count there were 3 Volo pilots in the fly-offs.
Here are a few awesome pics of John's dragon Volo, stolen from Bobby's FB page.
Dec 07, 2021, 01:17 PM
over it
I Placed 3rd in flyoffs with a Volo SL flown the duration of the contest
Discussion Aloha F5J from JimAero pguim Electric Competition Soaring-F5J/F5K/ALES/E-Soaring 215 Jul 05, 2019 06:39 AM
Discussion Taser F5J (carbon) from Soaring USA airporter Electric Competition Soaring-F5J/F5K/ALES/E-Soaring 2 Oct 25, 2016 12:27 PM
Discussion E-volo takes first (public) manned flight CactusJackSlade Multirotor Drone Talk 3 Apr 10, 2016 05:47 AM
Discussion Volo pdb issue. deekon FPV Equipment 8 Oct 22, 2015 09:31 PM
Discussion Volo pdb issue. deekon Multirotor Drone Electronics 1 Oct 11, 2015 11:43 PM
