May 10, 2017, 10:19 AM
Question
alternator repair
The alternator in my jaguar e-type 4.2 is slightly off. i would like to keep the car completely origional, so i dont want to buy a new alternator. is there a way to fix the alternator without causing damage or replacing parts?
May 10, 2017, 08:54 PM
If its not something silly like a slipping belt, then,
usually its a small electrical part failure.
Go to a E-type website and see if there is a common way that these alternators fail.
Check and see the availability of these parts---rectifiers, brushes, diodes, internal regulators, etc.
Fix it yourself, or take it to an autoelectric shop.
Also a possibility exists that the alternator can be rebuilt--looking stock externally-- but have completely revised internals, with higher amp output.
Feb 28, 2018, 04:16 AM
There are specialized shops in rebuilding alternators.
Oct 19, 2018, 09:20 AM
diode trio or internal regulator are usually what goes out on Lucas alternators.
Mar 20, 2019, 03:13 AM
I think I go fly
pyrobus's Avatar
Check diode bridge
If by slightly off you mean the voltage is like 12.8 instead of 13 to 14 then one of the diodes may have failed
New Product $15.99 RROSD Alternative - Realacc HUBOSD ECO H Type w/STOSD8 Current Sensor 5V 12V D lmpuIse Mini Multirotor Drones 0 Jul 15, 2016 09:59 PM
Discussion Repair, Repair, and Repair takeoff1 Fuel Plane Talk 2 May 15, 2009 08:32 PM
Discussion Depron alternate sources or alternative? Lomcevak Foamies (Scratchbuilt) 11 Aug 24, 2006 01:03 AM
Discussion Repair's Repair's Repair's Rocket Ronnie Slope 4 Jan 16, 2006 03:38 AM
Repair, Repair, Repair like2fly Beginner Training Area (Aircraft-Electric) 6 May 20, 2003 09:28 PM
