May 09, 2017, 07:53 PM
Guidance on beginner rc foam planes to develop
Hello all kindly suggest RC foam planes for beginner to be developed from scratch
May 09, 2017, 08:17 PM
Hot glue held together by foam
balsa or carbon's Avatar
The scratch built foam plane I use to teach first time RC flyers is the EzFly . It is very stable , and can be slow flying if built lightweight . Also , the motor/prop are protected in a nose first crash .
Here is one of mine :
Copy of EzFly with under-cambered wing (1 min 57 sec)
Let me know if you want to build an EzFly , I can help you through the whole process .
May 10, 2017, 08:40 PM
Thanks surely I am interested in building one..please friend guide me
https://www.youtube.com/watch?v=VxaUadvhgbc
May 10, 2017, 09:58 PM
Do you already have an RC aircraft transmitter and receiver ?
Do you already have electronics ..... motor , ESC , servos , battery ? The weight of your electronics will determine the size EzFly you should make .
Do you have sheets of foam ? If so , what is the thickness ?
May 10, 2017, 10:07 PM
No I don't have any .I am starting from beginning but can get them.I have used transmitter and receiver in rc boats in past and have idea on them.Kindly guide me which is fine for a new user
May 11, 2017, 02:18 AM
Do you know of an RC hobby store where you live , or an online RC hobby store that ships to your location ? If so , send me a link to their website so I can see what they have available , then I can make a recommendation .
May 11, 2017, 07:53 PM
In past I got it from https://www.horizonhobby.com/
May 11, 2017, 09:07 PM
Ok , what is your budget for transmitter/receiver , motor , ESC , servos , batteries , battery charger , propeller , hardware , etc ? If you can afford to get everything from Horizon Hobby , then I'll start with recommending a Spektrum DX6e ( or higher ) transmitter with receiver :
https://www.horizonhobby.com/radios/...ceiver-spm6650
If you want to get everything in one order from Horizon Hobby ; let me know and I'll list all the electronics , etc. that will work for an EzFly .
How thick is the foam you'll be using ?
May 12, 2017, 10:58 AM
Thanks please guide me with one site I used in past http://www.rcbazaar.com I wanted to see if any electronics you can recommend from here like transmitter,other parts like servos etc I'll get from local or hobby.Please guide me with other constructing parts like foam etc
May 12, 2017, 12:28 PM
From RC Bazaar , these items will work for an EzFly :
Transmitter/receiver : http://www.rcbazaar.com/product.aspx?productid=2011
Battery : http://www.rcbazaar.com/product.aspx?productid=4912
Battery charger : http://www.rcbazaar.com/product.aspx?productid=992
Motor : http://www.rcbazaar.com/product.aspx?productid=2398
ESC : http://www.rcbazaar.com/product.aspx?productid=4792
Connectors ( ESC to motor ) : http://www.rcbazaar.com/product.aspx?productid=207
Props : http://www.rcbazaar.com/product.aspx?productid=2475
http://www.rcbazaar.com/product.aspx?productid=316
Servo ( you'll need two ) : http://www.rcbazaar.com/product.aspx?productid=794
Control horns : http://www.rcbazaar.com/product.aspx?productid=4200
Can you get foam locally where you live ? Try to get sheets about 5mm - 6mm thick .
I use hot melt glue to assemble foam parts .
You'll also need :
tape
wood ( to mount motor to , then wood/motor is glued/taped to plane ) .
sticks ( for wing spar and pushrods ) , bamboo works well .
cutting surface
cutting blades ( VERY sharp for clean cut , a dull blade will tear the foam )
Here are the plans for the EzFly ( pdf file ) : https://www.rcgroups.com/forums/show...6&d=1334660760
You'll need a computer and printer . Open the pdf file on Adobe Reader and enlarge the plans to 100% . Then on the printer's setup page , select "poster" , "cut marks" and "labels" . The printer will print out tiles that will be assembled into poster sized plans to make templates for your foam pieces . The pieces should look like in the photos below :
May 12, 2017, 05:55 PM
When I went back to check to see if the links to RC Bazaar worked , I noticed that most of their products are out of stock ..... and sometimes the links don't work ( I get a server error message ) .
Do you know if HobbyKing or Banggood ship to where you live ? If so , I can list links for products from one of those online stores .
Banggood has free shipping ( to the USA ) on most items ...... maybe it will be the same for you . Here is an example of a transmitter/receiver from Banggood :
https://www.banggood.com/FlySky-FS-i...rmmds=category
I have personally used that transmitter/receiver and know it works well .
May 12, 2017, 07:59 PM
Thanks..both sites bangawood&horizon ships to my country.Please guide me with both to see overall charges .I'll manage to get other accessories like foam ,servos from my local stores.Also guide me what type of foam is needed any particular type
May 12, 2017, 09:26 PM
Any type of foam will work . See what you can get in sheets about 5mm or 6mm thick .
Ok , here's a list from Banggood .
Radio transmitter/receiver : https://www.banggood.com/FlySky-FS-i...content=227736
Motor : https://www.banggood.com/SunnySky-X2...l?rmmds=search
ESC : https://www.banggood.com/Hobbywing-F...mds=mywishlist
7035 propeller : https://www.banggood.com/Gemfan-5030...l?rmmds=search
Control horns : https://www.banggood.com/10Pcs-HM-St...mds=mywishlist
Servos ( need two ) : https://www.banggood.com/TowerPro-SG...mds=mywishlist
Battery ( get as many as you can afford ) : https://www.banggood.com/ZOP-Power-1...mds=mywishlist
Battery charger : https://www.banggood.com/SKYRC-E3-2S...mds=mywishlist
JST plug to connect battery to ESC : https://www.banggood.com/Wholesale-5...l?rmmds=search
May 12, 2017, 09:45 PM
Here's a list from HobbyKing ( select "global" warehouse at top , if it comes up United States ) :
https://hobbyking.com/en_us/turnigy-...___store=en_us
or least expensive reliable very basic radio :
https://hobbyking.com/en_us/hobby-ki...___store=en_us
Motor ( this is my favorite motor ) : https://hobbyking.com/en_us/hextroni...___store=en_us
ESC :
Servos (2) : https://hobbyking.com/en_us/turnigyt...___store=en_us
Battery :
https://hobbyking.com/en_us/zippy-co...___store=en_us
Plug to connect ESC to battery : https://hobbyking.com/en_us/male-xt6...___store=en_us
propeller :
battery charger ( Euro plug ) https://hobbyking.com/en_us/hobbykin...___store=en_us
control horns : https://hobbyking.com/en_us/large-gl...___store=en_us
motor stick mount : https://hobbyking.com/en_us/electric...___store=en_us
May 13, 2017, 10:00 PM
Thanks for the info,I'll slowly begin once the accessories come.I wanted to know while the foam is glued is there any type of table scale or any board to measure dimensions ?
ESC :
Battery :
propeller :
Discussion Beginner Foam Plane for a heli pilot? Thoemse Electric Plane Talk 10 Nov 21, 2016 10:32 AM
Help! Beginner needing guidance Ronnoc74 Beginner Multirotor Drones 25 Nov 15, 2015 02:29 PM
Discussion Gifting a beginner FPV plane - guidance required gitssac FPV Talk 2 Oct 24, 2015 09:29 AM
Discussion beginner to rc foam plane thebigelephant Foamies (Scratchbuilt) 14 Mar 07, 2011 05:56 PM
Question Esky? Beginner needs basic RC heli guidance stoddardvilla Micro Helis 15 Mar 26, 2007 05:23 PM
