Folding Propeller Adapter Assembly 5/38mm with Blade Stopper
This unit was designed just for these types of pusher prop application and it fits 5mm motor shafts and has a 5/8mm (M8) prop shaft adapter with a 38/8mm alloy yoke.
Stop Those Blades from Crossing
Folding pusher props like you see on many UAV and FPV planes are great for when you want to soar with no power. The propeller blades will fold back reducing drag and allow the plane to glide through the air more efficiently. Most folding props are used in the front of a plane in a tractor configuration and the prop blades rest against the fuselage when folded back and allow for easy restarts. In the pusher configuration, there is no fuselage to stop the blades and they can fold back all the way to a point where they can cross and get tangled up in each other. That is bad news as when you go to start the motor back up, the blades are stuck and now you are forced to land. There is an easy way to prevent this from happening though with this prop adaptor that features a blade stopper.
This unit was designed just for these types of pusher prop applications and it fits 5mm motor shafts and has a 5/8mm (M8) prop shaft adapter with a 38/8mm alloy yoke. The blade stopper is fiberglass and it rests on the aluminum yoke for strength and will prevent the prop blades from over rotating.
Check out the Folding Propeller Adapter Assembly 5/38mm with Blade Stopper here
May 08, 2017, 09:37 AM
RCG Admin
Jason Cole's Avatar
Ahead of your time... : )
May 08, 2017, 12:07 PM
In the heading photo, what is the plane?
May 08, 2017, 12:09 PM
Forward ever, backward never!
Brainstorm's Avatar
During a recent interview on the QuadTalk podcast, Tim Nilson from GetFPV mentioned inventing and selling something like this many years ago as well.
I simply have to get a pusher prop plane first, before I can try out the concept.
May 08, 2017, 12:25 PM
RCG Admin
Jason Cole's Avatar
I think it's an Aeronaut Aero-Master.
May 08, 2017, 02:04 PM
thanks, I'll have a look.
May 08, 2017, 06:53 PM
KE Spins make me dizzy.
I literally JUST finished this wing last night...
Now to find an 8"/9" folding prop so I can use that.
Jason Cole -- Since this is my first flying wing (and probably will sport some FPV equipment), what prop would you recommend that I use to have a successful first flight? 4s pack (can do 6), 45a esc and 1000kv motor.
May 08, 2017, 09:30 PM
RCG Admin
Jason Cole's Avatar
Do you have a link to that motor?
May 08, 2017, 11:51 PM
Motor in question:
https://thumbs.worthpoint.com/zoom/i...1253f157e8.jpg
It's a medusa research afterburner V1
May 09, 2017, 07:43 AM
Bill Glover's Avatar
Discontinued some time ago, I think.
Latest blog entry: Eachine QX65 FPV quad review
May 09, 2017, 10:37 AM
RCG Admin
Jason Cole's Avatar
Originally Posted by Sabin
Motor in question:
Not a lot of info on that one, but my best guess would an 8-10" diameter prop. I don't have ecalc anymore and I couldn't find any recommendations anywhere so I'd start with an 8x6 and do an amp test to see what it is pulling and go from there.
May 10, 2017, 06:20 AM
spudvr's Avatar
Also check out Mark's work on the Mini Talon
http://www.itsqv.com/QVM/index.php?t...e_Folding_Prop
Mar 20, 2018, 06:55 PM
Does anyone know how or where to get blades for the Aeronaut Aeromaster? I bought a used one and all the blades are broken. It needs some fiberglass repair too but I can handle that. Thank you all.
Mar 22, 2018, 06:39 AM
An itch?. Scratch build.
eflightray's Avatar
Is this site any help --
http://www.espritmodel.com/sailplane...-spinners.aspx
They show a 3-blade set up here --
http://www.espritmodel.com/aeronaut-...ropellers.aspx.
A UK advert on the Aero Master quote these prop sizes --
Motor prop 15 m/sec; 8 cells RPM P(out) 2-blade 3-blade actro C6 10x8" 10x6" 25 A (36 A/Stand) 8.500 175 W actro CL5 10x8" 24 A (36 A/Stand) 7.600 175 W actro CL4 10x7" 10x5" 28 A (38 A/Stand) 9.200 200 W 2-blade 3-blade
Discussion Gemfan 5152 5.1 X 5.2 3-Blade Propeller 5.0mm Mounting Hole for Racing Quadcopter GeekBuying Geekbuying.com 0 Apr 06, 2017 09:49 PM
Discussion Gemfan 5152 5.1 X 5.2 3-Blade Propeller 5.0mm Mounting Hole GeekBuying Geekbuying.com 0 Apr 01, 2017 06:02 AM
Discussion Tarot folding propeller adapter on sunnysky v4010 alsoares Multirotor Drone Talk 0 Aug 05, 2016 02:28 PM
News KDE Double and Triple-Propeller Adapters (folding-style props) RCGroups Update Multirotor Drone Talk 97 Jul 01, 2016 10:02 AM
Help! Diameter of this adapter and propeller hole - DD: E-flite adapter & GWS 4530 blades superchuchi Micro Helis 16 Aug 04, 2008 01:55 PM
