Aug 20, 2017, 12:08 PM
robertus's Avatar
Finally, project is completed.
Enjoy, flight with full painting.
MiG-29 Single EDF Project completed (3 min 46 sec)
Aug 20, 2017, 12:25 PM
jumo004's Avatar
Slicker than slick !!!!
Aug 21, 2017, 04:41 AM
Beautifuuulllllllllllllllllll.....Congrat Robertus!!!
Aug 22, 2017, 04:12 PM
Pro Hoarder
turbonut's Avatar
Well done
Latest blog entry: In flight
Aug 24, 2017, 09:26 PM
Fantastycznie lata! Kongratulacje Robert. Mam nadzieję że ty jesteś zadowolony bardzo z sukcesem tego lotu.
Aug 26, 2017, 01:35 PM
robertus's Avatar
Thanks guys. I'm very happy, she flies very smooth.
I was worried about this flight, because a lot of people wanted to see her in the sky. It was like a second maiden for me (after painting and detailing).
Interesting thing, afterburners are visible in daylight very well.
Aug 28, 2017, 12:05 PM
Robertus, This is beautiful. It looks, flies and sounds exceptionally exciting.
Congratulations
Solly
Sep 01, 2017, 01:17 AM
Slowly but sure... I want this to be my first plane with a perfect finish like your plane Robertus ... hope I can. I thought this would be a very big bird ... I was so excited !!!
Sep 01, 2017, 07:02 AM
robertus's Avatar
First part is up side down.
You do job well. I'm keeping crossed fingers for you.
What is the foam thickness? Mostly I used 5mm and 7mm depron.
Sep 01, 2017, 10:33 PM
The thickness of the foam that I use everything is 3mm... . Because at this time I do not have EDF, so I think again to try to change it into a kind of pusher. hopefully i succeed.
Sep 01, 2017, 11:20 PM
robertus's Avatar
I see. So your version may be lighter than main, and you will be able to do really slow low passes, because of low wing loading.
Nice!
Sep 07, 2017, 05:11 AM
Hi Robertus ... a little progress from me. After a few days break due to work accident at the time of cutting plywood and foam finally had to be 3 sewn....😀 But it's okay. Today I can continue again the project. But ... When i want to group all of the section, It turns out the size does not match the frame (less long). I do not know where the wrong, because I already have existing plans. Maybe when printing, which should be a full page but I cut it into A4 size paper. So I have to patch the parts that do not fit that..i hope this is still OK...
Sep 07, 2017, 07:27 AM
robertus's Avatar
I wrote that you have to trim frames depends on what thickness you have in foam for covering.
If you cover with 3mm foam you have to cut 3mm in any frame parts.
In plans all thickness are set to 0mm.
Sep 07, 2017, 10:54 AM
O.K Robertus .. actually I also have used 3mm for the part of the frame. O.K ... I will try to patch it. And hopefully the results are smooth
Nov 18, 2017, 09:14 AM
Hi Robertus ... can i see the detail of Elevator construction pict and how to install it to body plane....thankyou so much
New Product MIG-29 EDF 70mm Jet with thrust vectoring PDF Plans crispy1074 Foamies (Scratchbuilt) 1 Feb 11, 2014 02:24 PM
New Product MIG-29 with thrust vectoring 70mm EDF Jet. PDF Plans crispy1074 Foamy EDFs 0 Feb 10, 2014 10:17 PM
My MiG-29 for single 480MF Haldor Electric Ducted Fan Jet Talk 63 Feb 22, 2002 12:51 PM
