Jul 05, 2017, 03:53 PM
robertus's Avatar
Afterburners
MiG-29 Arduino afterburner (1 min 3 sec)
Jul 06, 2017, 11:59 AM
OMG...Its Very2 Beautifuullllllllll...Perfect Project....You Rock!!!
Im very Speechless....Congratulation Robertus....Congratulation
Jul 08, 2017, 02:27 AM
robertus's Avatar
As usually (for me), at the end of the project I've made a small summary.
How to make MiG-29 with Single EDF (2 min 14 sec)
Jul 09, 2017, 08:57 PM
Can only say....Incredible ... speechless ...!!!
Congratulations ...the Project is done ... very Beautiful Bird....
Jul 09, 2017, 10:35 PM
osern's Avatar
worship++
It occurred to me to have this idea to disguise EDF as gass bomb between F-14 or SUs, and you did first! nice work and finish! I love it!
Jul 10, 2017, 11:36 AM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Super cool build!
Jul 11, 2017, 07:37 AM
Robertus,
Very impressive and inspiring. Thanks for sharing.
Solly
Jul 25, 2017, 02:15 PM
robertus's Avatar
Ok Guys, here are the plans.
But I have to warn you those are not plug and play plans, they are closer to draft.
They are just unfolded surfaces from sketchup 3d model I have made.
So for example no offset is marked for foam thickness. You have to think about it when you want to use my plans.
But If you have some questions I will try to explain to you my plans.
Jul 27, 2017, 02:38 AM
Wooohoooo....finally you share the plans. Thanks a lot Robertus. After i print, this requires a little modification and need to think when assembling, especially in the fusellage and engine. There are some images thats i do not understand. But it will give it a try. So if i still confused i will ask to ask you. OK...i'm on the track nowand prepare to make it too. Hopefully the results are as good as you mke. I am very excited...Uuuyeeaaahhhhh!!!
Jul 27, 2017, 09:18 AM
newcomer's Avatar
Robertus, where did you get those cross-section drawings? another great build. you are an artist!
david
Jul 27, 2017, 10:22 AM
marek84's Avatar
I t`s a work of art Robertus .
Well done
Jul 27, 2017, 11:40 AM
robertus's Avatar
@Spetnazer. Wow, Did you print it on A4 format? It is a lot of gluening. Usually I print on the roll printer. I have few other photos made during build, so I can share if you will need support. Don't worry.
@newcomer, what do you mean cross-section drawings?
Jul 27, 2017, 02:23 PM
Originally Posted by robertus
We hope we will see this painting schema on real jet during 100th Anniversary of Polish Air Force next year.
Will see, keep your fingers crossed.
Niesamowite. Przepiekne jest te malowanie. Jest bardzo pod wrazeniem jak ja zauwarzylem ze ty ten samolot recznie pomalowales.
Jul 27, 2017, 02:28 PM
Ja tez zbudowalem samolot Sam I pomalowalem mojego spitfire-a w schemacie Jana Zumbacha. Tu jest moj link do mojego modelu. I jeszcze staram sie pisac po polsku bo ja jestem z kanady
https://www.rcgroups.com/forums/show...-spitfire-mkVb
Jul 27, 2017, 03:52 PM
robertus's Avatar
Dobrze piszesz po polsku. Też czytałem autobiografię Zumbacha. Pan Brown to bardzo barwna postać.
But lets switch to English, we can continue in PM jeśli chcesz.
New Product MIG-29 EDF 70mm Jet with thrust vectoring PDF Plans crispy1074 Foamies (Scratchbuilt) 1 Feb 11, 2014 02:24 PM
New Product MIG-29 with thrust vectoring 70mm EDF Jet. PDF Plans crispy1074 Foamy EDFs 0 Feb 10, 2014 10:17 PM
My MiG-29 for single 480MF Haldor Electric Ducted Fan Jet Talk 63 Feb 22, 2002 12:51 PM
