This thread is privately moderated by old4570, who may elect to delete unwanted replies.
May 07, 2017, 04:36 AM
old4570's Avatar
Mini-Review
Rainbow 2 Part 4 ( Motor and Pod (?) )
Product page
The ply mount is way small for a 2212 and its alloy mount ...
So I had to remove the mount and screw the 2212 directly to the ply mount ( see pictures )
I put the servos in sideways , flush with the surface of the wing ...
I also ran the servo wires through the slot cut for them .
A) The servo wire slot is a very fine cut , you may wish to use a BBQ skewer to open it up so that the wires are easily pushed in .
B) Dont glue anything !
The engine pod / fuselage ....
There literally are no instructions regarding its instillation what so ever ...
A) Work out where you want to cut the slots for the fuse / pod
B) Make sure your motor prop has clearance
C) Try an not mount it too far forward
D) It really is hard to get it wrong
E) I put the rear fuse ( mount legs ?) about 5mm inboard from the servo wire slot ... And tried very hard to keep everything central .. ( I used calipers )
When having done the rear slots , I then measured / marked / and cut the central slots , fitted the fuse / pod and then marked / measured / cut the forward slots ..
Did it slowly and carefully ...
Also used the BBQ skewer to open up the slots so that the Ply legs would insert without force ...
I haven't glued anything in place yet .. I will pop in the ESC / Receiver / and battery and see how much room I have , locate the goodies , and then see about the CG .. Once everything looks good I will glue things in place ...
New Product Racerstar BR2205 2600KV Rainbow Motor--Real Coloful BGjim Multirotor Drone Power Systems 7 Oct 07, 2016 03:18 AM
New Product Racerstar BR2205 2300KV Rainbow Motor--Real Coloful BGjim Multirotor Drone Power Systems 10 Sep 15, 2016 04:49 AM
Help! 4 in the pod/ 2 in the wing The_Builder Hand Launch 0 Aug 26, 2016 03:00 PM
