This thread is privately moderated by old4570, who may elect to delete unwanted replies.
May 06, 2017, 12:21 AM
old4570's Avatar
Mini-Review
DW Rainbow 2 flying wing ( Part 2 )
Rainbow2 part 2 (4 min 23 sec)
Well I stuffed up , I don't know what happened ?
Instead of turning the camera on , I was turning the camera off ! ( My bad )
product page DW Rainbow2 Flying wing
So here we go !
The wing is 3 piece , and has some 6 carbon spars that need to be glued in place ( That's what I did today ) Video shows me gluing in a carbon spar .
I did want to document the entire build but stuffed up ..
First thing I did was hot glue the wings together .. ( Actually hot glue makes for an excellent bond )
I got the left side perfect , but got the alignment wrong on the right by about 1.5mm ( Spar cuts )
Seriously , hot glue holds very tight - I had to cut the panel off with a knife and re - hot glue !
2nd times a charm , the wing is fantastic - really straight !
Next came gluing in the spars , I used 5 minute epoxy for this ..
The epoxy did dissolve some of the print of the wings ( Cheap epoxy ) ...
Now the resulting wing is very straight , the assembly was extremely simple ( very noob friendly process ) and I can see how instructions would only need to be very basic ( The included instructions dont really cover wing assembly at all ) , but it is very much bush league ( assembling the wing )
1) Put the pieces you want to glue on the table , test fit ( push them together ) check alignment !
2) Apply hot glue to one side , then push the the parts together making sure to align correctly
3) Carefully check to see if you glued the wing to the table , if you have , very gently ply lose from the table ..
With hot glue the process takes 30 seconds , if that long .. And the bond is excellent ..
Installing the carbon spars :
I used a knife to cut through the glue lines ( where the wing was glued together ) to get the spar to seat correctly ...
After some test fitting to make sure the carbon spars sit deep enough in the foam , I apply glue and place them in the wing one at a time ...
Try and do all of them , and you may find a spar or two lifting out of its grove ..
I guess foam safe cyno would be the go here , would make fitting spars very quick and painless .
And that is where I am up to , the wing is glued , the spars are in , and the ply fuse was hot glued for test fitting ..
Hmmm , the engine mount ( ply ) looks a little small for the motor I had in mind ...
Just going to let the wing ( epoxy cure ) ..
Then I might do the servos / control horns / and the ply fuse ...
Though I might want to fit a motor first , and all I have ATM is a 2212 2400kv that might be good on 2s ...
Cool Dancing Wings Flying Wing Rainbow with 1000mm & 800mm & 600mm Wingspan ! DW Hobby Flying Wings 34 Jun 27, 2018 12:51 PM
New Product [Upgraded Version]DW HOBBY Rainbow flying wing--Seeking reviewers BG Tobey Flying Wings 239 Dec 22, 2017 10:49 AM
New Product DW HOBBY Rainbow Ⅱ Flying Wing 1000mm Wingspan EPP FPV RC Airplane KIT - $28 lmpuIse Flying Wings 5 Dec 10, 2016 01:06 AM
Cool DW Hobby Rainbow Improved ---Wing Reinforcement & new color scheme ! DW Hobby Flying Wings 10 Sep 09, 2016 04:17 PM
