May 08, 2017, 08:05 PM
Originally Posted by ariaAQ
Here, compared to my green 500 size and dji phantom.
LoL. 800 to 1500 sized...
I think only some professional or industrial project will using this size.
May 09, 2017, 12:48 AM
Haha, it's okay my friend.. It's possible to make copter with high capacity load, just need Extra Large Frame, Motor, Props and Money..
I like to design something, already designed Extra Large Multi Function X8 Copter.
Estimated empty weight (without payload and batt) around 9-10kg, max total weight 25kg,
Motor XM9010HD-6, props 24" and 22".
But still in my dream, i have no money to build that monster right now.
Here is my design:
Thanks a lot, in Denmark we are only allowed to lieft 7kg (in the law) else we need to start flying from a airplan place where its allowed, but what i think its just to build a huge one for fun and becures its posibule
Thanks for your design, how big are you probs here? and have you a more detail design of it?
May 09, 2017, 02:19 AM
ariaAQ's Avatar
1100mm diagonal motor to motor, 20x20mm rectangular carbon tubes, 3mm carbon plate.
4x10000mAh 6S batt or 6x10000mah 6S batt depend on load.
May 09, 2017, 02:32 AM
ariaAQ's Avatar
Same basic frame design as my green quad, different landing gear and canopy, here my green quad build:
https://www.rcgroups.com/forums/show...-Foldable-Quad
May 09, 2017, 02:54 AM
same 7kg for overall weight.
Heavier then that need the commercials permit to fly.
In parallel or series?
May 09, 2017, 03:16 AM
ariaAQ's Avatar
My plan for 6S setup (parallel), no need for High Voltage esc's, big and expensive..
Jun 23, 2019, 09:11 AM
ANGRYbirdFPV
KillerUAV's Avatar
Hi everyone, seeing you all talking about heavy lifting high efficiency Hexcopters made me want to jump on in for a few questions. I use the E-Calc to work out my motor esc battery set up usually but with the build I did on a T960 or 960mm Tarot hex frame I ran into problems. I have a weight of close to 8.2KG without batteries but with current motor and props attached and also includes the H3 Gremsy Gimbal and a6000 Sony camera. So that is the payload I am trying to lift for filming advertising. Motors I tried were 320KV Sunnysky which had good performance but got too hot and only had Flight time of around 4-5mins. I am looking to find a new motor prop config to run 6s and a prop limit of 18" so I will need the 18x6.2 CF props and I am looking at probably either the TMOTOR U7 280KV or P60 340KV motors but I am afraid to spend up to $2000 on motors just to find I get a measly 6-8mins. I am hoping to get at least 11-14mins on a AUW of 11-12.5KG Is this feasible with the frame restrictions of a max 18" prop? Thanks so much your help is invaluable.
Jun 24, 2019, 11:45 PM
ariaAQ's Avatar
I think you can do that with P60-340 + 22" props, no with 18" props
Discussion High Power & Mid Power motors + JonathanPM Rocketry 0 Mar 17, 2017 06:59 PM
Question A good reflexed airfoil with high lift? Root_ender Modeling Science 14 Dec 07, 2015 01:42 PM
Question FPV: what does motor Lift power means? Mohshaheen Beginner Multirotor Drones 5 Nov 01, 2015 12:02 AM
Discussion High flight time quad with good lift power i3dm Multirotor Drone Power Systems 0 Mar 23, 2014 05:57 AM
Question High Lift Power Plane? mightyaad Electric Plane Talk 6 Nov 17, 2013 12:13 PM
