May 02, 2017, 08:51 PM
Banggood Staff
New Product
iRangeX RX803 Super Micro Receiver Compatible Frsky D8 X9D Plus SBUS Output-FREE TEST
Hi guys,
Here is a new product--
Link:
https://www.banggood.com/IRangeX-RX803-Super-Micro-Receiver-Compatible-Frsky-D8-X9D-Plus-SBUS-Output-p-1147916.html
Description:
Brand name: iRangeX
Item number: RX803
Voltage: 3.3V
Output: SBUS
Weight: 0.4g
Compability: compatible with Frsky D8 X9D Plus
Features:
* The world’s smallest & lightest FrSky compatible full telemetry receiver, weights only 0.37g and measures 11.2mm x 8.51mm.
* This RX has full analog and hub telemetry support and digital SBUS output.
* The PCB was designed to be as small as possible and can be soldered by hand.
* Compatible with Frsky D8 X9D Plus.
See more:Click here.
May 02, 2017, 08:52 PM
Banggood Staff
reserved
May 03, 2017, 04:48 AM
Dutch RC Reviewer
Dutch 79's Avatar
Very Nice Tobey,
Count me in for the review then I can compare with several other Frsky receivers.
Done several reviews for banggood already.
May 03, 2017, 09:01 AM
Toby you need to clear your inbox. Trying to send a pm to you and its full
May 04, 2017, 05:19 AM
sounds good
interesting. thanks.
May 04, 2017, 05:25 AM
Dutch RC Reviewer
Dutch 79's Avatar
It's 8 channels with sbus.
So 1 signal, 1 power and a ground wire.
May 04, 2017, 11:11 AM
Sumfear's Avatar
It's wonderfull how technology is making this things smaller and cheaper every day...
I would line to test range to see if it can fit even a 130.
Please I would like to review it.
My last review on Dtx03:
Review Eachine DTX03 from Banggood 1/2: Unboxing and latency test (4 min 14 sec)
May 04, 2017, 11:15 AM
tests?
looking forward to see how it tests.
May 04, 2017, 11:38 AM
Dutch RC Reviewer
Dutch 79's Avatar
Smells like a troll,
May 09, 2017, 12:17 PM
I have emax babyhawk + taranis QX7, good for test this RX
May 10, 2017, 09:39 AM
This is fishpepper designed uSky receiver (http://fishpepper.de/projects/usky/) that uses opensource firmware (http://fishpepper.de/projects/opensky/). Thank You, Simon, for brilliant work!
This RX has failsafe (constant, stopped ppm output), telemetry: 2 analog channels, RSSI, and hub telemetry forwarding, is very small and opensource! You probably will not use all these features on your micro build, but it just has everything you need.
It is interesting what range can be expected with this super micro receiver? Put me in the list, I would like to test this RX.
Jun 17, 2017, 03:24 PM
I flew it as far as I could at a park I normally fly at and could not even get an RSSI warning...
iRangeX RX803 Super Micro RX 💡🚩🔥 (5 min 20 sec)
Nov 14, 2017, 09:40 PM
What happened to these? Looks like they have been eliminated from BG. Did they not work well? Or the batch sold out and no more have been ordered?
New Product 2.4G 8CH D8 Mini FrSky Compatible Receiver With PWM PPM SBUS Output --FREE TEST BG Tobey Radios 45 Oct 14, 2018 12:52 AM
New Product Tiny Frsky 8CH Receiver Compatible With FRSKY X9D Plus DJT DFT DHT For QX95 QX90 QX80 mrgilchen Multirotor Drone Electronics 10 Feb 09, 2018 07:01 PM
Discussion 2.4G 8CH Micro Frsky D8 Compatible Receiver With PPM SBUS Output IKKI Mini Multirotor Drones 2 Jan 08, 2017 07:08 PM
New Product iRangeX RX16 16CH Compatible Receiver S-BUS CPPM for Frsky X9D X9E X9DP X12S nitbeat Radios 3 Sep 25, 2016 12:25 AM
New Product iRangeX RX16 16CH Compatible Receiver S-BUS CPPM for Frsky X9D X9E X9DP X12S reviewdroneworld Multirotor Drone Electronics 0 Sep 23, 2016 07:15 AM
