This thread is privately moderated by bigtruck169, who may elect to delete unwanted replies.
May 02, 2017, 12:55 PM
cheap OSD system + kk board
Drivers issues when flashing Betaflight/Cleanflight firmware
http://www.dronetrest.com/t/fix-any-...-firmware/3603
F4 V5PRO Flight Controller
DutchRC - GEPRC AX5 Airbus MONSTER Quad ! Part 3: How to install the Flight Controller (F4 V5 Pro) (21 min 3 sec)
Fontic FPV 5.8Ghz Circular Polarized Clover Leaf Antenna High Gain Aerial Set w/RP-SMA Plug
https://www.amazon.com/Fontic-5-8Ghz.../dp/B01D8J828Q
need RP-SMA male for antenna
https://www.banggood.com/F4-V5PRO-Fl...BoCp9UQAvD_BwE
MCX-SMA connector antenna
EMAX Skyline32+OSD Flight Controller! https://www.rcgroups.com/forums/show...ght-Controller!
https://oscarliang.com/best-osd-quad...display-video/
MINIMOSD W/ KV TEAM MOD V2.0 - good quality http://www.readytoflyquads.com/minimosd
Suppo OSD is the cheapest to do that. Accuracy not the best, but still very useful. low quality, but hey it has GPS and only costs $50. I use it. Skylark OSD and CE OSD also in that low cost basic price range.
Storm OSD is the next step up, and is better quality, plus allows you to have autopilot if you wish. It uses a Barometer for altitude, which is better than any GPS, but can still have errors. The amps and mAH are way out of calibration at this time. Costs about $140. I use it and I like it. But it is still an econobox OSD.
The basic EZOSD can be set up to work great and is reliable and well designed, but has minimal features for about $170. Note sure if it has baro? anyone?
The higher end ones cost $300-500 to get fully optioned out. Eagle Tree, RVOSD, Feiyutech, RubyuThere (which is more of a telemetry + full autopilot system). I use Eagle Tree in 2 planes
https://www.rcgroups.com/forums/show...long-range-fpv
Why would you not just get these:
https://www.banggood.com/Betaflight-...l?rmmds=search
https://www.banggood.com/7M8M-Ublox-...l?rmmds=search
FC with OSD plus GPS. This post: https://www.rcgroups.com/forums/show...TH-for-CC-CC3D suggests that it can do RTH.
7M/8M Ublox M8N GPS Module for APM Pixhawk CC3D Naze32 F3 Flight Control
OMNIBUS Betaflight F3 AIO V1.1 Flight Controller with Integrated OSD Barometer Support SD Card
https://hobbyking.com/en_us/afroflig...ontroller.html
AfroFlight Naze32 Rev5 Acro FunFly Controller
When you say you have a flight controller, what are you referring to vs an autopilot? Most of the cheap, standard copter F1 and onward FC boards can be reflashed with INAV. NAZE32 is about $10 at BG. Add a basic $10 gps and you get RTH, which is all you really need...for just $20. INAV can also do waypoints etc, though it takes some effort to get it set up well.
XCSOURCE APM2.8 ArduPilot Flight Controller+6M GPS+915Mhz Telemetry+ Power Module RC150
https://www.newegg.com/Product/Produ...Q&gclsrc=aw.ds
F4 Omnibus where to connect XSR via SBUS? No VFAS on Taranis?
https://www.rcgroups.com/forums/show...FAS-on-Taranis
DIY Raspberry Pi Drone: Mechanics Part 1
http://www.deviceplus.com/how-tos/ra...ard-1-carousel
Jul 07, 2017, 10:51 AM
brush motor with dsm2
https://www.hobbytown.com/beecore-f3...4-dsm2/p542785
New Product Matek Systems HUBOSD8-SE 9-27V - new PDB + OSD board nitbeat Multirotor Drone Electronics 2 Mar 19, 2017 10:56 AM
Discussion Need some tips on gimbal for cheap fatshark fpv system together with kk 2.1.5 babipsylon Multirotor Drone Talk 1 Aug 16, 2015 06:03 AM
Rave HK KK V2 Quad board (and other recent KK boards) randall1959 Multirotor Drone Electronics 2584 Aug 11, 2014 02:01 PM
Discussion kk black board with a fye-tech osd? joe_crash Multirotor Drone Talk 0 Mar 04, 2012 02:10 PM
Discussion KK board or cheap gyros? emberjelly Multirotor Drone Talk 11 Sep 02, 2011 10:47 PM
