May 01, 2017, 04:19 AM
We Help You Fly :)))
rotorsupport's Avatar
New Product
20x20mm FC with 25A escs ??? is this real ?
Saw this at Banggood !!!
Check it out here
for the price , it could be the best powerbox for a 75mm-120mm quad !
So banggood just announced 3 new 20x20 Powercubes !
the new onces looks like its updated.
the first one is XJB F425 with OSD :
https://www.banggood.com/20x20mm-XJB-F425-Dshot-Flytower-Micro-F4-AIO-OSD-BEC-Flight-Control-25A-Blheli_S-2-4S-4-In-1-ESC-p-1148284.html
Specification:
Item Name: 20x20mm Dshot Flytower Micro F4 AIO OSD BEC Flight Control & 25A Blheli_S 2-4S 4 In 1 ESC
Model: XJB F425
Weight: 6.5g
Usage: for 65mm-250mm Frame Kit
Micro F4 Flight Control Board ( D-Shot Version):
MPU: MPU6000-SPI
CPU: STM32F405RGT6, dual 8K.
Black Box: Flash 16M
Input Voltage: 2-4S Lipo
Built-in Betaflight OSD to adjust PID
BEC Output: [email protected]
Size: 25x25mm board, 20mm mounting holes (M2)
Weight:2.3g
Support Subs/PPM/DSMX receiver
25A 2-4S Blheli_S BB2 4 in 1 ESC:
Input Voltage: 2-4S Lipo battery
Constant Current: 25A
Peak Current: 30A (10S)
BEC Ouput: NO
Firmware: BLheli_S 16.5
Size: 27x27mm (main board)
31x31mm ( including pad)
Installing Hole: 20x20mm
Weight: 4.2g
CPU: SILABS EFM8BB2 48MHZ
MOS Tube: TOP QUALITY MOSFET
Firmware: Betaflight 16.5
Support Damped Mode, Oneshot125, Oneshot42, Multishot, Dshot150, Dshot300, Dshot600, forward and reverse
second one is XJB F410 :
https://www.banggood.com/20x20mm-XJB-F410-Dshot-Flytower-Micro-F4-AIO-OSD-BEC-Flight-Control-10A-Blheli_S-2-3S-4-In-1-ESC-p-1148282.html
Specification:
Item Name: 20x20mm XJB F410 Dshot Flytower Micro F4 AIO OSD BEC Flight Control & 10A Blheli_S 2-3S 4 In 1 ESC
Model: XJB F410
Weight: 6.5g
MPU: MPU6000-SPI
Weight:2.3g
10A 2-3S Blheli_S BB2 4 in 1 ESC:
Input Voltage: 2-3S Lipo battery
Constant Current: 10A
BEC Ouput: NO
Size: 27x22mm (main board)
30x27mm ( including pad)
Weight: 4.2g
Third one is XJB F310
https://www.banggood.com/6g-20x20mm-XJB-F310-PBF3-EVO-Flight-Control-AIO-PDB-BEC-D-shot-10A-Blheli_S-2-3S-4-in-1-ESC-p-1148281.html
Specification:
Item Name: 6g 20x20mm XJB F310 PBF3 EVO Flight Control AIO PDB BEC D-shot & 10A Blheli_S 2-3S 4 in 1 ESC Flytower
Model: XJB F310
Weight: 6g
Usage: for 65mm-130mm Frame Kit
6Dof PBF3 EVO Flight Control Board ( D-Shot Version):
MPU: MPU6000
CPU: STM32F3CCT6, Flash 256K.
Input Voltage: 2-6S Lipo
Size: 23x23mm board, 20mm mounting holes (M2)
Weight:2.3g
Firmware: BF3.15 Firmware
Built-in RC/LC filter
-6Dof version, without Barometer and Compass
BEC Ouput: NO
Weight: 4.2g
the new boards looks really great .. old one was in my shopping cart but now i will order one of each of these when they become available.
May 01, 2017, 05:11 AM
making crashing a lifestyle!
dutchcommando's Avatar
wow....
now lets wait for 11xx motors who can draw that kind of amps.
May 01, 2017, 05:21 AM
Originally Posted by dutchcommando
wow....
i think you could run these on a 210 sized quad .. problem will be how to mount it coz its only 20x20 mounting holes !!
DYS are coming with new motors i think .. 1104 rated for 4s .. i hope that will be soon
May 01, 2017, 10:48 AM
IKNOWNOTHING
yes it real, I had been using the fc on its own in a build, its a much better board than the pico blx,
the only down side is the mounting holes are M2 for some weird and annoying reason
May 01, 2017, 02:55 PM
Can't these 2M be drilled carefully to 3M ?
May 01, 2017, 02:58 PM
Fan of just about anything RC
SoloProFan's Avatar
Is this the same board as on the XJB-80 and 75? These are also HGL Tech products.
Latest blog entry: For the love of the hobby!
May 01, 2017, 03:18 PM
We are not men, we are DEVO 7e
xanuser's Avatar
I have the v 1, great little boards.
Does the buzzer on v 2work for you? On v1 buzzer pads are dead.
Latest blog entry: MY notes/ Ascent 2"build notes
May 01, 2017, 07:11 PM
what buzzer volts do you use ? 3v buzzer ?
i just can't find a 3v buzzer anywhere !
May 01, 2017, 10:49 PM
westers47's Avatar
Think bigger with smaller components. I have been waiting for something like this when I designed this frame, its a 222mm stretch X frame. Using a Runcam Swift mini and a 20x20 FC can allow for a very narrow body even with replaceable arms. Wind resistance would also be lower with the weight. The weight of this frame would have to be around 70 grams if not lighter. The M2 holes do make things more difficult.
Name: 220 strech X ultra light 2.JPG
Description:
Name: 220 strech X ultra light.JPG
Description:
May 01, 2017, 10:56 PM
westers47's Avatar
I forgot to mention Luminier has 20AX2 ESC with 20x20mm mounting but stacking two ESC's would make a pretty high stack.
http://www.getfpv.com/electronics/el...c-20x20mm.html
May 02, 2017, 12:17 AM
IKNOWNOTHING
I did drill mine out but the corners come off, it can still be mounted but only if using plastic screws as after drilling to 3mm a some of the pcb is exposed and will short on metal screws through the frame
Edit: this is the board i had been using which is similar but has a built in pdb
https://www.banggood.com/Mini-20x20m...?rmmds=myorder
waiting on my custom frame from armattan atm, should be sub 25g-ish for 4" using the new runcam micro, I was going to this fc and esc stack but its simply the m2 mounting which kills it as using real soft mounts makes a big benefit to flight performance, hopefully someone makes m2 soft mounts
May 02, 2017, 06:42 AM
Thanks , it was in my cart and now i removed it .. will look into other options
May 03, 2017, 02:39 AM
Just another user...
This is the FC/ESC combo that came with my Loki X4 Mini ultralight 4-inch pre-built quad from HeliPal.
Personally, I am not convinced that the 4-in-1 ESC board can handle 25Ax4. Not able to test this as the Loki setup (1306-2100kV motors, 4045 props on 4S) doesn't draw much current (I estimate less than 5A per motor) even at max throttle. And that's really more than one should be putting through the JST power lead connector anyway. Punch outs are pretty anaemic. But the setup is pretty light (less than 120g without battery) so flight times are in the 7~8 minute territory with a 600mAh/4s pack.
I am thinking of putting replacing the motors with 1407s to liven things up a bit. The battery connector will have to be upgraded to XT30, though.
May 03, 2017, 05:54 AM
Banggood announced new ones , hopefully these will be with 3mm mount holes
May 03, 2017, 08:49 AM
I doubt it. They have a new, F4 version arriving soon but the specs still show M2 mounting holes. But you can wish!
New Product Eachine Minicube 20x20mm Flytower (/w FC, OSD,ESC's,RX) Perfect for Tiny Builds nitbeat Micro Multirotor Drones 309 Oct 09, 2018 02:55 AM
New Product 6.5g XJB V1 F3 EVO FC AIO 5V BEC PDB with XR25A 25A Blheli 2-6S 4in1 ESC sevet Multirotor Drone Electronics 6 Jun 16, 2017 04:25 PM
Discussion 20x20mm FC with BFOSD, PDB tsly Multirotor Drone Electronics 13 Apr 26, 2017 09:16 AM
Help! can is use 25A ESC for FC 28-12 brushless motor 1534kv? PLZ help me munsaf Electric Motor Design and Construction 2 Sep 16, 2009 08:09 AM
ESC 25A and ESC 25A with governor mode rc-guy Power Systems 1 May 24, 2005 03:02 PM
